KILLANOLA Posted June 21, 2016 Share Posted June 21, 2016 I found my 95 pathfinder -XE 5 speed with the Clutch fluid missing and no pressure on clutch this morning. This happened about 5 or 6 months ago also and I used one of those pressure pumps to get the air out and fluid back in the system. But unfortunately That's not working this time around. There is still no pressure on the clutch pedal. I tried to pump it like last time but no pressure on it. All thoughts and ideas would be great appreciated as I'm kinda a notice when it comes too working on cars. Thanks, KILLANOLA Link to comment Share on other sites More sharing options...
NP670 Posted June 21, 2016 Share Posted June 21, 2016 (edited) Just finished working on mine...1. Check master cyl... 2. Check Slave... 3. Check clutch hose... 4. Check your pipings... Possible that there might be a leak somewhere Sent from my SM-N910T using Tapatalk Edited June 21, 2016 by NP670 Link to comment Share on other sites More sharing options...
KILLANOLA Posted June 21, 2016 Author Share Posted June 21, 2016 Im not really sure where those are located or look like? Link to comment Share on other sites More sharing options...
KILLANOLA Posted June 22, 2016 Author Share Posted June 22, 2016 I check 1 and 4 not sure where 2 and 3 are Link to comment Share on other sites More sharing options...
dirtbike23 Posted June 22, 2016 Share Posted June 22, 2016 2/3- located/installed @ chassis near bell housing. just follow your clutch line from CM going down to your slave cylinder Link to comment Share on other sites More sharing options...
NP670 Posted June 24, 2016 Share Posted June 24, 2016 Sent from my SM-N910T using Tapatalk Link to comment Share on other sites More sharing options...
NP670 Posted June 24, 2016 Share Posted June 24, 2016 (edited) Heres the clucth hydraulic system. Follow the piping or tube from the CM to the clutch damper, then from the damper down to the clutch hose. Make sure your hose is not worn or cracked. Then check the clutch slave. Try bleeding the damper till fluid comes out, then, Bleed the slave after. Hope this helpz Sent from my SM-N910T using Tapatalk Edited June 24, 2016 by NP670 Link to comment Share on other sites More sharing options...
