maddmark1981 Posted December 10, 2015 Share Posted December 10, 2015 . Drivers side door is freezing up and I can't get truck unlocked... What should I do? Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
RF600 Posted December 10, 2015 Share Posted December 10, 2015 I assume the cylinder is not working? If so take the cylinder out and attempt to clean it. If it is frozen you will have to get a new one and have it keyed to your current key. Until then crawl through the passenger side. 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted December 10, 2015 Author Share Posted December 10, 2015 It works fine when its mild but once it freezes up its impossible Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
Precise1 Posted December 10, 2015 Share Posted December 10, 2015 Take it out, clean it and then lubricate it with dry graphite powder. Either that or just have your polar bear pee on it to free it up as needed... B Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 10, 2015 Share Posted December 10, 2015 I would recommend something other than graphite for the door lock. I blew some into the driver's lock on my '95 and I think it got into the contacts for the electric locking, because that system went from occasionally glitchy to full-blown psychotic immediately afterwards. It did free up the lock, but it wasn't frozen from moisture, it was stuck from years of dust. Link to comment Share on other sites More sharing options...
ahardb0dy Posted December 11, 2015 Share Posted December 11, 2015 second on not using graphite, use pure silicone spray, WD40 came out with one has a green label on the can. If flock freezes, you can try heating the key with a lighter 1 Link to comment Share on other sites More sharing options...
