captandy Posted October 14, 2015 Share Posted October 14, 2015 Been looking ebay but it looks as if the back of my switch stamped "K".I TRIED SWAPPING MY WIFE'S 20O1 AND IT DIDN'T WORK..even though plugs fit..hmmm Link to comment Share on other sites More sharing options...
jyeager Posted October 14, 2015 Share Posted October 14, 2015 I'm confused as to why your wife's switch didn't work. Did you accidentally have the window lock button pressed? Before telling you where to find one, you need to ensure that it's your switch that's bad. It may not be the switch. Since you have tried a known good switch, you need to assume it's not the switch (unless you made the aforementioned mistake). As a triple-check, remove your switch and use a paper clip to jumper 2 pins in the connector that should roll your window down (or up as the case may be). 1 Link to comment Share on other sites More sharing options...
captandy Posted October 14, 2015 Author Share Posted October 14, 2015 Thanks for fast response..I too was confused..hers is a 2001..and stamped differently on back..but wouldn't work and actually started getting hot and slight burn smell! Quickly unplugged and put back in her truck..still worked. Link to comment Share on other sites More sharing options...
CNAM Posted October 14, 2015 Share Posted October 14, 2015 Might be worth a try. Link to comment Share on other sites More sharing options...
hawairish Posted October 15, 2015 Share Posted October 15, 2015 I agree with jyeager. I don't think there's any reason the other switch wouldnt work. You should check all the other circuitry and troubleshoot with the FSM; it's very clear about diagnosing this. What exactly is the problem with your current switch? Not sure the markings are relevant. If it comes down to it, there are a few PF/QX4's at my nearby junkyard that I can pull you one from. Link to comment Share on other sites More sharing options...
jyeager Posted October 15, 2015 Share Posted October 15, 2015 You said your truck is a 2003, but your profile says 2004. Can you confirm the model year of your truck? Link to comment Share on other sites More sharing options...
captandy Posted October 15, 2015 Author Share Posted October 15, 2015 It's 2003.. don't know how I wrote 04!ordered a switch off eBay fromm a 2003 maxima stamped the same on back. (K)...all motors work..will fill in here when I find out more.. Link to comment Share on other sites More sharing options...
captandy Posted October 15, 2015 Author Share Posted October 15, 2015 Just checked..profile says 03 Link to comment Share on other sites More sharing options...
captandy Posted October 15, 2015 Author Share Posted October 15, 2015 http://www.ebay.com/itm/141799656538 Link to comment Share on other sites More sharing options...
ferrariowner123 Posted October 17, 2015 Share Posted October 17, 2015 (edited) Think he was referring to this when he said your profile shows 04.... But the burning smell had me concerned, that means some miss wiring causing a short, have you check connections for damage, moisture, corrosion? -Kyle Edited October 17, 2015 by ferrariowner123 Link to comment Share on other sites More sharing options...
