Zero Posted September 30, 2015 Share Posted September 30, 2015 (edited) I've been prowling looking an answer to this but haven't found anything. I've got an 01 QX4 with 2" spring spacers. Considering these wheels (18x9 +25mm bs) http://www.bbwheelsonline.com/ultra-gauntlet-238b-wheels-18x9-6x5-5-6x139-7-25mm-matte-black-238-8984B/ I don't fully understand backspacing well enough to determine whether or not these will fit. with these tires (Grabber AT2 265/70/18) http://www.amazon.com/General-Grabber-AT2-Radial-Tire/dp/B00521F4W6/ref=sr_1_2?s=automotive&ie=UTF8&qid=1443506153&sr=1-2&keywords=general+grabber+at2&refinements=p_n_feature_five_browse-bin%3A6131683011 Tire diameter is 32.6" Running boards will come off of course I assume I would need to do some minor trimming to keep them from rubbing on the flares. Would I be better off going with a smaller tire or can I run these safely? Edited September 30, 2015 by Zero Link to comment Share on other sites More sharing options...
AkPrecision Posted October 24, 2015 Share Posted October 24, 2015 If your just running spacers on stock springs I don't know if you can fit 33s. I'm on ac 2" with fluerys 1" strut spacer and I had trim a bit on 285 75 16s with 16x8 4 backspace Link to comment Share on other sites More sharing options...
