hagge Posted September 23, 2015 Share Posted September 23, 2015 Hi! Bought a pair of new wheel side CV boots from 4x4 parts a while back. Don't know the brand. One of them is already torn where it sits on the axle, and it has a lot of "dry cracks" all over. The other one seems fine... I wonder if i did something wrong when installing one side ???? Can you recommend any after market brands that will last? Front end is cranked up a bit. Brands available here in Europe are for example: Blue print, Jakoparts, Japanparts, Sakura I read somewhere here that Rockford makes durable boots, but i can't find them over here. Link to comment Share on other sites More sharing options...
fleurys Posted September 24, 2015 Share Posted September 24, 2015 If I were you I would write to rockford : sales@rockfordcv.com and ask how much for shipping or a reseller in sweden. They are worth every penny... These are the last cv boot I bought and they are still in great shape (no cracks) ... S. Link to comment Share on other sites More sharing options...
patqx4 Posted September 24, 2015 Share Posted September 24, 2015 I put on a Rockford boot and it tore pretty much right away, no spacer lift on so it was running at stock tolorances. The standard rubber one I installed on the other side a year prior is still fine. Link to comment Share on other sites More sharing options...
hagge Posted September 25, 2015 Author Share Posted September 25, 2015 Ok Thanks! Will check with Rockford and/or Stock ones, but original spare parts are crazy expensive over here. One CV boot is around 90USD Aftermarket around 10USD Link to comment Share on other sites More sharing options...
porridgebird Posted October 7, 2015 Share Posted October 7, 2015 Check out this link. http://www.hippored.com/?portfolio=cuffia-facile-easy-boot-cv&lang=en. These boots could save alot of headaches. They look great if they will work. I have a 94 SEV6 4x4 Pathfinder and just discovered the passenger side outer boot is cracked. Cv joint not making noises or vibrations yet so I'm about to do some maintenance. Any opinions on the Italian company's cv boot or any helpful shortcuts will be mucho appreciato! Thanks, Randy Link to comment Share on other sites More sharing options...
BendRed Posted October 7, 2015 Share Posted October 7, 2015 Check out this link. http://www.hippored.com/?portfolio=cuffia-facile-easy-boot-cv&lang=en. These boots could save alot of headaches. They look great if they will work. I have a 94 SEV6 4x4 Pathfinder and just discovered the passenger side outer boot is cracked. Cv joint not making noises or vibrations yet so I'm about to do some maintenance. Any opinions on the Italian company's cv boot or any helpful shortcuts will be mucho appreciato! Thanks, Randy BRILLIANT! Wonder what diameter the axles are as I would guinea pig this product! Link to comment Share on other sites More sharing options...
porridgebird Posted October 7, 2015 Share Posted October 7, 2015 29mm axle diameter. I don't know what the Pathfinder axle diameter is. Hopefully the same. Link to comment Share on other sites More sharing options...
RF600 Posted October 10, 2015 Share Posted October 10, 2015 I had torn boots in my rig. I elected to just put shafts in instead. Depending on how long the boot has been torn you might be better off just replacing the shaft? Link to comment Share on other sites More sharing options...
