Jonhutson Posted August 22, 2015 Share Posted August 22, 2015 Gas gauge - I was sitting at a stoplight a couple of weeks ago, not revving the motor or hearing any difference in the pitch of the motor, but my gas gauge was going back and forth from full to empty pretty sporadically and continued for the rest of the drive - Now it either doesn't work at all or its correct, but I'm not seeing any actual difference in engine performance Temperature gauge - I haven't seen it act up, and I don't have any temperature problems - it's on/off when the fuel gauge is on/off All of the other gauges are working as they ought to. What is there for me to do to fix this? Thanks in advance. Link to comment Share on other sites More sharing options...
RedPath88 Posted August 23, 2015 Share Posted August 23, 2015 Pathfinder Common Problems/Fixes, Read this first! Talked about countless times in multiple threads, a simple search will turn up many results. 1 Link to comment Share on other sites More sharing options...
jaswyoung Posted August 26, 2015 Share Posted August 26, 2015 I'm new to pathfinders. we just received a bit of a beater for free, but no working temp or gas gauge (among other things I'm working to fix). As I've read most common problem is faulty voltage regulator on the instrument cluster. The original tested to 8.65V, so I think it is OK, but went ahead and bought a new one. Put it in last night, and still no gauges. dang. What is next most common fail point? Seems that having neither working is almost for sure to be related. hard to believe that both the fuel sensor and the temp sensors could both be out, but I guess it could happen, this thing is a bit of rust bucket...but it runs great! Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 30, 2015 Share Posted August 30, 2015 Welcome! I would pull the cluster and check the connections on the back, corrosion as well as loose connections can cause intermittent failure and sporadic behavior. Is your tachometer working correctly? Link to comment Share on other sites More sharing options...
