ChadderRiggs Posted July 29, 2015 Share Posted July 29, 2015 (edited) Pulled my tranny apart, as I've had no reverse and I finally lost 3rd and 4th. I was expecting a simple clutch, plates and band job.... But Nooooooo! Oil Pump shaft is toast, along with Reverse Drum getting torn up. I can get (eBay) a used oil pump for $99 and reverse drum for $60. But I've still got to buy a rebuil kit ($150), have a shaft turned on a lathe ($20) and have planetary gear pins Weld tight ($50) (this was all advised by my transmission guy) and a bushing set ($80) plus $300 for labor. So a total of $740... Pick and Pull has a '97 Pathy that I can get the tranny out of for $160. Can I make this work for my' 95? What would you guys do? I'm nickel and diming right now, but I do know that this kind of thing need to be done right otherwise I'm doing it twice... Otherwise.... Anyone want to trade? I love my Pathfinder and want to fix her, but I'm out of work until this is resolved. This is costing me money on both ends.... Oh and rents due on the 1st... Sacramento area if there's anyone out there that can help me, I'd super appreciate it. You all on here are great. Thanks! Edited July 29, 2015 by ChadderRiggs Link to comment Share on other sites More sharing options...
Kingman Posted July 30, 2015 Share Posted July 30, 2015 Yes it'll swap right in. Link to comment Share on other sites More sharing options...
ChadderRiggs Posted July 31, 2015 Author Share Posted July 31, 2015 Kingman, Have you done it or seen it? Do I have to swap anything, bellhousing or transfer case adapter? Also, did you grow in Vancouver? I did. Moved away in 2002. Cascade Park. Link to comment Share on other sites More sharing options...
Kingman Posted July 31, 2015 Share Posted July 31, 2015 It's common knowledge around here with a little searching. I've put a '98 trans into an '88, and the hot commodity nowadays is to swap an Xterra/Frontier SC trans in. All Pathfinders/Hardbody/Xterra/Frontier with a VG use an RE4R01A. All interchangeable so long as the units are 4x4. Haha yeah, been here all my life. In Camas at the moment Link to comment Share on other sites More sharing options...
APACHECHIEF13 Posted September 7, 2015 Share Posted September 7, 2015 What is the strongest automatic trans out there? I want to keep my crawler automatic. I have the l3n71b trans in it now and I love it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
