aussie4wheeler Posted July 2, 2015 Share Posted July 2, 2015 Hey guys. I am conducting a 48 state road trip next summer in my R50 02 pathy and she has just hit 181000. Next week I am doing a full engine rebuild including oil pump, timing chain, water pump, new pistons etc. While the motor is out is there anything I should pay special attention to or replace??? Link to comment Share on other sites More sharing options...
Rebelord Posted July 2, 2015 Share Posted July 2, 2015 Why a rebuild? What is warranting the project? Make sure to replace all vacuum lines and water hoses. There is a bypass hose in the back that's a PITA to get to. But if the engine is out replace it. Do your power valve screws. If the budget allows. There are custom Cams and tuners out there for the 3.5 just are pricey. Sent from fat fingers on S6 Link to comment Share on other sites More sharing options...
aussie4wheeler Posted July 2, 2015 Author Share Posted July 2, 2015 Thanks for the tip! The main reason for the rebuild is the last 2 vehicles that I have bought have given me nothing but problems after the first 6 months or so and I end up pouring all my money into them, I have a buddy who is a master mechanic who needs some money and offers to do the whole rebuild for $800. I pay for parts and I'll practically have a brand new pathy. With the 48 state trip over 30,000 miles with little money and no resources I want to minimize the risk of some thing major going wrong in the trip. Can you recommend a specific brand or type or hot cam/tune. What about converting to direct injection?? Link to comment Share on other sites More sharing options...
Rebelord Posted July 3, 2015 Share Posted July 3, 2015 Cam and tune. Just research Maxima and 350Z forums. But with those mods can come trouble. So stay stock. Honestly these engines are pretty bullet proof if taken care of. Many members have well over 150k on em no issues. My 3.3l Pathfinder has 212k miles. Only thing some guys have is a little oil consumption. But just keep it topped and go on. Here is a tip. Under your truck passenger side. About right under between the two doors there is a wiring harness. Inspect it. If its wet and reddish. Then it's the seal for a turbine sensor on the top of the transmission. With engine out. Replace that sensor and seal. It fails and thr fluid wicks it way through the harness to that spot. Very common especially in the Xterra side. Sent from fat fingers on S6 1 Link to comment Share on other sites More sharing options...
ferrariowner123 Posted July 3, 2015 Share Posted July 3, 2015 What about converting to direct injection?? Slow down there turbo. Have a gander at this article, its might answer that one for you. http://thechronicleherald.ca/wheelsnews/26226-direct-vs.-port-injection You'd have to completely redesign the head, and while i have seen custom heads made for the L-series engine (made into dual cam), its takes MONTHS of work, countless machines (ranging from ten of thousands to millions of dollars), and then the know-how to do all this. So yeah, not happening. I'll say what others have said, go stock. You put it nicely, its a 30,000 mile road trip. With any road trip, you want reliability i had a friend drive his 150,000 mile 95 pathfinder all the way to mexico (3800 miles round trip), 2 weeks after buying it, had zero issues. Keeping it stock, with quality replacement parts, is the way to go. Look into Variable Geometry Turbo's, Doppelkupplungsgetriebe transmissions, and 2 way differentials after the road trip. -Kyle Link to comment Share on other sites More sharing options...
aussie4wheeler Posted July 3, 2015 Author Share Posted July 3, 2015 Cool, thanks kyle, my intention always was originally to keep it stock. I got pressure from buddy's to tune it up/d it a cold air intake do this do that etc etc but I think its really a great designs as it is, no real need to go changing to much, im not gonna be towing anything but a canoe and some bicycles so it makes plenty of power as it is. If I throw money at anything I think it needs to be at suspension/tires and some of the accessories I have planned like light bars, CB, radar/laser jammer, aux battery/on board refrigerator etc. I appreciate all the input fellas, if you guys are ever in the northern MI/WI area hunting or traveling etc hit me up. I got a spare room abd plenty of tracks to go wheelin Link to comment Share on other sites More sharing options...
jyeager Posted July 27, 2015 Share Posted July 27, 2015 So have you completed the rebuild yet? Or is it yet to be started? If done, let us know how it turned out. If not...then I would throw a new idea out for you to think about. Others suggested cam change for increased power, but really the types of cams they were talking about would increase top end power which you don't want in an SUV. In fact, I think these trucks were cammed like cars in that they make too much top-end power and too little bottom end power. So if you went with a different cam, one that's tuned to make maximum VE around 2500 rpms is ideal. Peak torque might be at 3k. Does your friend's $800 rebuild include the typical machine work? Hot tanking the block, honing the cylinders (preferably with a torque plate) and the whole head rebuild (springs, retainers, and all that good stuff)? If you have the heads ported and polished and perhaps matched to the intake ports for a few hundred $ more, it can pay dividends in improved torque for years to come (just don't have them increase runner volume at all) 1 Link to comment Share on other sites More sharing options...
aussie4wheeler Posted November 5, 2015 Author Share Posted November 5, 2015 Thanks jyeager, I'm actually halfway through the build. I am sending the block and heads to a racing shop up in bloomer WI for hot tank and honing etc. I have all new valves and seals etc and .020" oversize pistons and rings. Do I still need to have the heads matched to the intake ports? Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
01Pathmaker Posted November 7, 2015 Share Posted November 7, 2015 You certainly don't NEED to do the port matching, but it would be well worth it if you do. Any decrease in turbulence, whether on the intake or exhaust side pays great dividends. But as jyeager stated, you really don't want to increase intake volume unless you plan to add a supercharger. Link to comment Share on other sites More sharing options...
aussie4wheeler Posted January 13, 2016 Author Share Posted January 13, 2016 (edited) Hey guys just thought you would like to know that the build is finished. The motor has 2 mins of run time on it. We will be doing the initial break-in tomorrow afternoon. Had a few issues with a coolant leak but it is sorted now. I'll post a list of everything I did to the truck and the parts I used a little later. Over all it was about a $3000 build. My local Nissan dealer was especially helpful. The parts guy bent over backwards to assist me as at every turn and even overnighted a new camshaft from California for me at their expense and allowed me to put a few technical questions to the techs out back and gave me employee cash prices on all my parts which added up to about %30 off OEM gear Sent from my XT1254 using Tapatalk Edited January 13, 2016 by aussie4wheeler Link to comment Share on other sites More sharing options...
aussie4wheeler Posted January 13, 2016 Author Share Posted January 13, 2016 [/img] Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
BrianD Posted January 17, 2016 Share Posted January 17, 2016 Hey guys. I am conducting a 48 state road trip next summer in my R50 02 pathy and she has just hit 181000. Next week I am doing a full engine rebuild including oil pump, timing chain, water pump, new pistons etc. While the motor is out is there anything I should pay special attention to or replace??? My 98 has 310,000 km on it and no problems - if it ain't broke then don't fix it. jus sayin' 1 Link to comment Share on other sites More sharing options...
aussie4wheeler Posted January 30, 2016 Author Share Posted January 30, 2016 I've completed the rebuild. Lots of time and money later she runs like a gem .still throwing a timing code P0011 that I have narrowed down to a cam phase gear which is my fault. I soaked them in a degreaser during the rebuild that corrodes aluminium... The dealer wants $560 per gear so I'm headed to a U-pull parts place today to get both of the gears. Only the bank 1 gear is bad but the bank 2 gear was soaked as well so I don't trust it Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
aussie4wheeler Posted January 30, 2016 Author Share Posted January 30, 2016 Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
