01Pathmaker Posted November 25, 2014 Share Posted November 25, 2014 Searched and didn't come up with any definitive answers, so here goes: Can the AirLift 1000 kit be used with 4x4designs 1" spacers? It's either this or I go with AC medium duty rear springs and 1" spacers up front. I occasionally tow a trailer and my current oem springs are shot. Would like to hang on to the stock ride when not towing. Link to comment Share on other sites More sharing options...
Yendor Posted November 25, 2014 Share Posted November 25, 2014 I have those airbags and I'll bee ordering the coil spacers soon. Yes i believe it should work together. Though I'll find out for sure when I go to install them. Link to comment Share on other sites More sharing options...
erathge Posted November 25, 2014 Share Posted November 25, 2014 Searched and didn't come up with any definitive answers, so here goes: Can the AirLift 1000 kit be used with 4x4designs 1" spacers? It's either this or I go with AC medium duty rear springs and 1" spacers up front. I occasionally tow a trailer and my current oem springs are shot. Would like to hang on to the stock ride when not towing. I dont see why they wouldn't work, they will be sitting in the spring the exact same way as they would if the spring wasn't sitting on a 1" spacer. I used to have them, but now that I have 2" AC springs they are not tall enough to do anything, basically they act as bump stops now. Link to comment Share on other sites More sharing options...
01Pathmaker Posted November 26, 2014 Author Share Posted November 26, 2014 My other question revolves around the Moog oem replacement springs. 96 calls for 81113, 01 calls for 81115. Are they different rates? All "lift" springs are listed for 96-04, can't seem to find specs on these anywhere. I'd like to go with whichever has better weight carrying capabilities. Link to comment Share on other sites More sharing options...
Precise1 Posted November 26, 2014 Share Posted November 26, 2014 The spacer will have to have a small relief in it and a thru hole for the air lin, but yes if it is solid other than that, then the airlift 'bags' should work fine. I suspect the reason for the different spring numbers is because they went with a more powerful motor in 2001 which would increase the towing capacity, so maybe the later version has a slightly stiffer spring rate to increase tongue weight capacity as well? Just speculation... B Link to comment Share on other sites More sharing options...
FriedEGs Posted March 15, 2018 Share Posted March 15, 2018 Reviving this topic: Anyone using Airlift with Fluery's 2" kit in the rear? My theory is that the Airlift won't work because the spacer increases the gap between the bottom 'raised' seat and the top portion, (where the bumpstop was originally mounted) Anyone else have experience with this? Link to comment Share on other sites More sharing options...
Bax03SE Posted March 15, 2018 Share Posted March 15, 2018 Yes they work together. I ran the airlift 1000 with 2.5 inch spacers in the rear. The airlift kit calls for removing the bump stops in stock application. With the spacers, youll need to leave the bump stop in place and the bump stop will fill the extra space from the lift and still allow the air bags to work by resting on the bump stop. I had to trim about an inch off the bottom of the bump stop to get the right length to match up with the air bags. Link to comment Share on other sites More sharing options...
TowndawgR50 Posted March 15, 2018 Share Posted March 15, 2018 Used to run airlifts w spacers, no no problem. Got tired of the bags leaking and upgraded to LR springs. 1 Link to comment Share on other sites More sharing options...
