Dma251 Posted November 15, 2014 Share Posted November 15, 2014 I'm getting ready to replace the shocks on my 91 SE with Bilstein 4600 monotubes. I want to add some adjustable load-levelling system since I sometimes use a rtt, or carry heavy gear, and other times I'm running light. his leads me to two basic options: Airbags that ride inside the coils like the airlift 1000, or monroe or ACdelco rear airshocks. The advantage to the airbags is that I can run the bilsteins in the back, too. The disadvantage is it is more complicated and I worry that the bags might bind in the coils under high degrees of articulation. Does anyone have any experience with either of these on a pathfinder? Link to comment Share on other sites More sharing options...
Precise1 Posted November 16, 2014 Share Posted November 16, 2014 I'd go with the bags. It gives you the most flexability and redundancy of the two choices and they seem to work out well/be perfectly durable. This is what has been discussed here... http://www.nissanpathfinders.net/forum/topic/37190-air-lift-1000-leveling-air-bags/ B Link to comment Share on other sites More sharing options...
Nefarious Posted November 16, 2014 Share Posted November 16, 2014 For what it's worth, my truck sees the exact same situations as you described and my choice is going to be the airbags. With a small 12v compressor or belt driven compressor, it makes the system very versatile and once those bags are deflated they won't hinder your articulation. Link to comment Share on other sites More sharing options...
Dma251 Posted November 16, 2014 Author Share Posted November 16, 2014 Thanks, guys. I ordered the bilsteins for all corners and airlift 1000 kit. Now its on to tires. Thinking of getting 5 31" BFG AT's, but Im tempted by those goodyear MTRs, too. Link to comment Share on other sites More sharing options...
