green180 Posted November 13, 2014 Share Posted November 13, 2014 A friend and I installed the carrier I had sitting in my garage, it's off a 1997 but it fit perfect, I'm looking for ideas to reinforce it more Link to comment Share on other sites More sharing options...
Yendor Posted November 13, 2014 Share Posted November 13, 2014 Nicely done. I was thinking of doing this myself. How sturdy is it? I would like to mount a 31 and a gas can or two. Link to comment Share on other sites More sharing options...
green180 Posted November 13, 2014 Author Share Posted November 13, 2014 I put my weight on it with it open and it didn't sag, I want to add more bracing though before I add a tire and gas can Link to comment Share on other sites More sharing options...
Precise1 Posted November 14, 2014 Share Posted November 14, 2014 Looks good! Hard to get a reference for the back bracing, and I haven't looked at that part of the car, so I don't have any good suggestions... B Link to comment Share on other sites More sharing options...
01Pathmaker Posted November 14, 2014 Share Posted November 14, 2014 Did you make those plates? Very nicely done. Looks like you've thoroughly sandwiched the mounting area, from a fabrication/structural integrity stand point, I don't think it could get better without tying the upper and lower mounts together on the backside with one solid backing plate, but I think that would be extremely difficult and overkill. Link to comment Share on other sites More sharing options...
green180 Posted November 14, 2014 Author Share Posted November 14, 2014 Thank you, I made those plates as close as I could to the shape of the quarter panel, I'm thinking of attaching both plates I'm just waiting on more time I would've liked to hole saw a hole in the second layer of the c pillar and weld a pipe to both layers for more strength, I worry that over time the panel will crack around my plates Link to comment Share on other sites More sharing options...
bushnut Posted November 15, 2014 Share Posted November 15, 2014 looks good to me, my only advice would be to water proof the hell out of it. so you don't get any corrosion down inside that area. Link to comment Share on other sites More sharing options...
green180 Posted November 15, 2014 Author Share Posted November 15, 2014 Haha thanks bushnut, I did, I ended up using window sealer silicone in between the carrier and body, same with the latches Link to comment Share on other sites More sharing options...
ahardb0dy Posted November 15, 2014 Share Posted November 15, 2014 Should have used either lock washers or Nylock nuts on the inside to prevent the nuts from loosening, good job otherwise. 1 Link to comment Share on other sites More sharing options...
Nefarious Posted November 16, 2014 Share Posted November 16, 2014 That's pretty much exactly what I did when I added a carrier to my wd21. 4 years later now and still no issues at all and it's been carrying a 33x12.5 tire. My backing plates are slightly thicker gauge steel but it really shouldn't matter, yours are ample, it's just what I had laying around. Link to comment Share on other sites More sharing options...
green180 Posted November 16, 2014 Author Share Posted November 16, 2014 Thanks nefarious, eventually ill install lock washers, the 2 inside nuts are welded on, on both brackets, it's tough to get my hands in there so I did that instead Link to comment Share on other sites More sharing options...
ahardb0dy Posted November 16, 2014 Share Posted November 16, 2014 Don't see any welds, that's why I commented, welding the nuts to the bracket would work. Link to comment Share on other sites More sharing options...
ferrariowner123 Posted November 16, 2014 Share Posted November 16, 2014 Love the handy work. I should really pop open my rig and see just what nissan has put back there, for strength. Maybe it's fairly simple, I feel like looked once when Andy was putting his swing away on, anyway, if I'm bored today, I'll grab some shots. -Kyle Link to comment Share on other sites More sharing options...
green180 Posted November 17, 2014 Author Share Posted November 17, 2014 That would be awesome I've been wondering what's back there, please do Link to comment Share on other sites More sharing options...
hawairish Posted November 17, 2014 Share Posted November 17, 2014 Curious to know, too. I see the different parts numbers for the fender depending on if fender flares and the tire carrier were included. Definitely doesn't appear to be an extra, separate bracket of any sort. Still, your approach is probably sufficient. Are your plates bonded to the metal in any way, like JB Weld? Link to comment Share on other sites More sharing options...
green180 Posted November 17, 2014 Author Share Posted November 17, 2014 No just window sealant and bolts, I haven't heard any noises yet and it's still sturdy, we'll see once I take it off road with all the flexing Link to comment Share on other sites More sharing options...
ferrariowner123 Posted November 17, 2014 Share Posted November 17, 2014 Alright, I'm off from early fairly early today, I need to get some measurements from back there, so I'll snap some photos for you guys. -Kyle Link to comment Share on other sites More sharing options...
green180 Posted November 18, 2014 Author Share Posted November 18, 2014 Thank you Link to comment Share on other sites More sharing options...
