NIssanBoston Posted April 11, 2014 Share Posted April 11, 2014 I recently had a p0138 code which is the passenger oxygen sensor after the cat, well I've just recently switched it like 10 mins ago took me 2 hours because of the wires and @!*% , then I accidently put the anti seize compound near after the threads where the sensor is I turned the car on and I still have a check engine light code for the same thong, I also broke one of the clips that holds the electrical sensor in place by accident but I didn't think thatd do anything. Need help and would be greatly appreciated. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted April 11, 2014 Share Posted April 11, 2014 Well, the light won't go out immediately. You need to clear the code or drive it around a bunch. OBD2 will clear itself if it runs two consecutive test cycles without any failure. Hopefully you didn't replace the wrong sensor. Link to comment Share on other sites More sharing options...
NIssanBoston Posted April 11, 2014 Author Share Posted April 11, 2014 It was bank 1 sensor 2 , which is passenger side on the code after cat, would breaking those clips off by accident affect it? i have a zip tie on it for now so it's tight and doesn't vibrate loose and what about the anti-seize compound that do anything Link to comment Share on other sites More sharing options...
Rebelord Posted April 11, 2014 Share Posted April 11, 2014 All my clips are busted. Antinsieze will be fine. Clear the code or drive a bunch. As said Sent from my Moto X Link to comment Share on other sites More sharing options...
Precise1 Posted April 11, 2014 Share Posted April 11, 2014 x3 on clear the OBD2 of codes and drive... B Link to comment Share on other sites More sharing options...
NIssanBoston Posted April 11, 2014 Author Share Posted April 11, 2014 Reset the code, lets see if I fixed it, also noticed there were Bosch o2 sensor, I automatically assumed there were going to be Denso so I went with that lol. Link to comment Share on other sites More sharing options...
Alkorahil Posted April 11, 2014 Share Posted April 11, 2014 Bosch is fine. As the othere stated, it will take a while to go off on its own, or you can clear the codes and see if it comes back on. Link to comment Share on other sites More sharing options...
PivoArch Posted May 8, 2014 Share Posted May 8, 2014 What was the part number for the bosch senso? Rockauto has them as left and right and I don't know which one is which side. Thanks. Link to comment Share on other sites More sharing options...
NIssanBoston Posted May 9, 2014 Author Share Posted May 9, 2014 I got the denso oxygen sensor i didn't get the bosch sensor sorry bud :\ Link to comment Share on other sites More sharing options...
Leo98 Posted May 10, 2014 Share Posted May 10, 2014 I have learned to disconnect the battery + and - cables from the terminal to reset the check engine soon light. I fix the problem first, then disconnect the battery and see if the light comes back on or not, so far this method has worked for me. Link to comment Share on other sites More sharing options...
NIssanBoston Posted June 2, 2014 Author Share Posted June 2, 2014 Oh thank for the info! Thats great because I don't have a scan tool so I'll definitly do that next time , thanks! Link to comment Share on other sites More sharing options...
ferrariowner123 Posted June 2, 2014 Share Posted June 2, 2014 I have learned to disconnect the battery + and - cables from the terminal to reset the check engine soon light. I fix the problem first, then disconnect the battery and see if the light comes back on or not, so far this method has worked for me. Technically you're suppose to disconnect the battery ever time you replace something electronic on a car. It's not the end of the world, but it prevents accidents and inadvertently does what you said. -Kyle Link to comment Share on other sites More sharing options...
Leo98 Posted July 5, 2014 Share Posted July 5, 2014 Sorry about that wording, i always disconect the battery before doing any work, i just meant to reset the check engine light to disconnect both of the cables like you are removing the battery, then hook back up and the light goes off, but will come back on if there still is a problem. 1 Link to comment Share on other sites More sharing options...
