jyeager Posted February 21, 2014 Share Posted February 21, 2014 Hey, I want to replace my driver's door hinges. I feel that the best way to do this is to leave the door on the car, but remove the front fender to gain clear access to the hinges. Then with the door closed I can replace 1 hinge at a time and not need a second set of hands, or a hoist, or a rope and jackstands, alignment issues....all of that hassle that complicates the process if I were to open the door and begin unbolting hinges. If I'm wrong, stop me. Otherwise, can you tell me how that fender comes off? Where are the fasteners? Does it require removal of the front bumper/grill? Is it easy to separate from the inner fender? Are the fasteners and their locations less than intuitive? (that's always the case for me!) Thanks in advance. Link to comment Share on other sites More sharing options...
Towncivilian Posted February 21, 2014 Share Posted February 21, 2014 Although this is for the passenger's side, this TSB has pretty thorough instructions on fender removal. I think it should help you out: https://drive.google.com/file/d/0B5mpmm482r0VVGVqSG9yeHJwVHM/edit?usp=sharing Link to comment Share on other sites More sharing options...
bushnut Posted February 21, 2014 Share Posted February 21, 2014 (edited) I've replaced my passenger side fender. I don't think removing the fender will help with replacing the hinges. Edited February 21, 2014 by bushnut Link to comment Share on other sites More sharing options...
Towncivilian Posted February 21, 2014 Share Posted February 21, 2014 My driver door hinges sag too and I've looked into replacing the hinges. It does not seem physically possible to remove and replace the hinges without removing the fender to gain access to the hinges' fasteners. Link to comment Share on other sites More sharing options...
