ChrisFreeman Posted October 3, 2013 Share Posted October 3, 2013 Hello everybody My 92 SE has a fuse labeled "seat heat" and I would love to know what it is for. I do not have heated seats and I do not think it was even an option back in 92. Thanks in advance. Link to comment Share on other sites More sharing options...
92Path_68CJ Posted October 3, 2013 Share Posted October 3, 2013 Interesting. I'd really like to know too. Try looking in FSM? Link to comment Share on other sites More sharing options...
ChrisFreeman Posted October 3, 2013 Author Share Posted October 3, 2013 Interesting. I'd really like to know too. Try looking in FSM? Does your pathfinder also have the same fuse. I am just really curious. I will try the FSM. 1 Link to comment Share on other sites More sharing options...
92Path_68CJ Posted October 3, 2013 Share Posted October 3, 2013 (edited) Does your pathfinder also have the same fuse. I am just really curious. I will try the FSM. I wish I could tell you. I haven't owned a pathfinder in about 6 months. Edit: I take that back. I found an old photo of the fuse door and see the fuse labeled Seat Heat. The label on the fuse chart can be seen to the right of the flash. Sorry about the flash by the way. Edited October 3, 2013 by 92Path_68CJ Link to comment Share on other sites More sharing options...
ChrisFreeman Posted October 3, 2013 Author Share Posted October 3, 2013 I wish I could tell you. I haven't owned a pathfinder in about 6 months. Edit: I take that back. I found an old photo of the fuse door and see the fuse labeled Seat Heat. The label on the fuse chart can be seen to the right of the flash. Sorry about the flash by the way. I took a look in the fsm and couldn't find any mention of it. I just want to know what it is for. Any guesses? Link to comment Share on other sites More sharing options...
Slartibartfast Posted October 3, 2013 Share Posted October 3, 2013 Seat heaters were an option on these. I think the LE had it standard with the leather seats. IIRC if you find a set of heated seats, and the switches/harness, you can just plug them in, put the fuse in, and there you are. On my SE there are two blanking plates on the center console where the switches would go, and the Seat Heat fuse slot is empty. It seems to me like a great place to tap in a radio or something that you want fused but don't want to bother with an in-line fuse holder for. Link to comment Share on other sites More sharing options...
silverton Posted October 3, 2013 Share Posted October 3, 2013 All the trucks use the same wiring harness, cheaper to build this way. The harness plugs for the heated seat coils are under the seats not being used. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 3, 2013 Share Posted October 3, 2013 Did WD21 cloth seats have heated seats as an option? Do WD21 seats fit in an R50? Link to comment Share on other sites More sharing options...
adamzan Posted October 3, 2013 Share Posted October 3, 2013 Yes, and I don't know. My old wd21 had a heated drivers seat, but not passenger. Link to comment Share on other sites More sharing options...
silverton Posted October 3, 2013 Share Posted October 3, 2013 I've also heard you can take the heating element out of a seat that came with them and swap it in to a seat that didn't. Link to comment Share on other sites More sharing options...
Trogdor636 Posted October 3, 2013 Share Posted October 3, 2013 My yard recently had MINT heated cloth seats. No idea why I didn't buy them. Link to comment Share on other sites More sharing options...
morpheus Posted October 4, 2013 Share Posted October 4, 2013 (edited) Most seat heaters are just a basic heating pad hooked up to a switch and 12v. You can pull the pad out of just about any make/model at a wrecker, doesn't have to be a Nissan, just has to have the right amount of surface area. Edited October 4, 2013 by morpheus Link to comment Share on other sites More sharing options...
92Path_68CJ Posted October 4, 2013 Share Posted October 4, 2013 You can buy DIY kits all over the net as well. It's more of the cool factor of OEM/ factory installed heated seats IMO. I know I'll be searching on my next pathy, that sounds nice in the winter. Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 4, 2013 Share Posted October 4, 2013 If they have AC seats like the Cadillac xlr than I would want that, down here in FL not much use for heated seats ! Link to comment Share on other sites More sharing options...
morpheus Posted October 5, 2013 Share Posted October 5, 2013 If they have AC seats like the Cadillac xlr than I would want that, down here in FL not much use for heated seats ! Maxima has cooled seats, you could use those and at least keep it all Nissan! Link to comment Share on other sites More sharing options...
