Upgraded Wheels
94WD214x4
Hey folks, is there any reason I cant run 15x10 wheels with 3.5 BS on a 3" lift? Or any reason I shouldnt run 16x8/16x10 wheels with 3.5 BS?
Ive found a few deals and figured the 33x12.5 tires I bought would fit a little better.
Thoughts?
I run 15x10 steel rims with 33x12.5 duratracs on my 93 pathy. Not sure the rim offset but its VERY negative. Tires stick out past fender flares a few inches. I have 3-4" suspension lift and 3" body lift and I also did a lot of trimming up front as well as cut, move back and weld the pinch seam behind the front tire so that I can turn my wheels fully with the "small tire package" steering stops . I can crank the wheels fully with no rubbing.
