What percentage of 94-95 Pathfinders had the exhaust manifold issue?
jwblue
Are you referring to the broken exhaust studs? If so that has been happening since 86.5 when the Hardbody first came out with the V6, Not sure on the V6 equipped cars as I never owned one.
No idea on the warranty extension but someone on here will be able to answer that one.
Hard to say the percentage, I think it had more to do with conditions, useage and luck. Both my 95s did not have any significant issues other than one with a slight tick when cold. The manifolds were straight enough to put on my friends 91 when he fixed his broken stud/exhaust leaks.
Yes, I have heard that there was an 'extended warranty' up to 100k, but you better ask very carefully/get it in writing before hand. It might have expired simply due to age, but some dealers have honored it while others claim no such thing or total ignorance. I know it has been discussed here before so a search might be in order. Regardless, check with your local dealer beforehand...
