UPDATE - Unfortunately, the data that was lost is unrecoverable by the host.  If you joined between May 26th and Jan 13th please feel free to sign up again.  In addition, all posts and messages during that time have also been lost.  At this point there is nothing that can be done, other than to move forward from here.
Thank you for your patience and understanding.
-NPORA Mod Team
*Updated: 02/06/2022 5:26PM PST
DRL are not on.
Yup got them here in canada. check the fuse, relay, n' box beside the battery. I unplugged my DRL's from there, then the box fell off its holder causing a short. put it back in its place and changed the fuse, everything's fine now. Checked it and returned it to its unplugged state.
unplugged then 'cause i was thinking of getting sum HIDs. Not 'till i can find them projectors though...
Just remember you still need the DRL, you can get a VI (Vehicle Inspection) ticket if they are out. That requires repair and correction at a licensed facility. I know it is unlikely but it does happen.
I will be using a set of LED light as DRL's once I iron out the projector...project :blush02:
u guys got DRLS wtf screw that im moving to Canada
Funny - those w/o DRL's want them, lots with DRL's want them gone... :clap:
