88pathoffroad
FREE DOWNLOAD: 86-89 Pathy Vehicle Security System
Awesome stuff 88, thanks man...
Say, what happened to the site, I could not access it for several days?
Joe
OK I tried arming the system as described (turn ignition to ON, turn alarm on, turn ignition off, shut doors and wait 30 seconds), the LED didn't flash. After 50 seconds I shook the car jumped up and down on the bumper and nothing. Opened the door and didn't stick the key in the ignition and waited fifteen seconds, nothing. Does the engine have to be running when you turn the alarm switch to on? The manual says that you can't disarm the system completely so what gives?! pssd
Dude, if it doesn't work, it doesn't work. Someone may have pulled the fuse for it or clipped the wires. You're going to have to remove your driver's side seat and get in there to see for yourself.
Will do, but probably not for a couple of weeks at least. It's not that important it just bothers me that it doesn't work.
Make sure the doors are closed when doing the programming.
The links don't work. Anybody who has a copy, reupload it? I'll make it into a single PDF for simplicity's sake.
Anyone still have this? Links are broken :-(
Anyone on here have these files? I could really use them..
Take a look at the PDFs in this thread: http://www.nissanpathfinders.net/forum/topic/19755-fix-your-keyless-entry/?p=339766
It's labeled for 1990 models, but it should be similar for 87-89. (For the 90s, it's not actually keyless entry. It's really just for the security system that had the on/off switch on the dash.)
Best of luck. :aok:
Edited by xterra
If anyone does have copies of those images then send them to me and we will host them here at NPORA, but unfortunately 88's damagedreality.com website has been gone for a long time now.
