Hytekrednek Posted March 4, 2013 Share Posted March 4, 2013 When running with engine at idle the revs bounce and wont go below 1200 rpm. I saw something like this posted before but cant find it now. Any insight as to the cause would be much appreciated. Link to comment Share on other sites More sharing options...
mluczaj22 Posted March 6, 2013 Share Posted March 6, 2013 check codes... Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 6, 2013 Author Share Posted March 6, 2013 I have checked for codes and didn't get any, unless I did it wrong. I know that there is info on here that shows how to get the codes so I will give it a shot again. James Link to comment Share on other sites More sharing options...
Kingman Posted March 7, 2013 Share Posted March 7, 2013 Clean the MAF sensor and make sure the plug contacts are completely free of corrosion. Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 7, 2013 Author Share Posted March 7, 2013 Ok will try that this weekend and see how that goes. Thanks for all of the help. Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 15, 2013 Author Share Posted March 15, 2013 Have not been able to check the sensor yet. With just getting a 93 Pathy and work having me on call from Sunday till this Saturday, I have not had much time for working on my trucks. I will be parking the 86.5 and slowly start working on getting the stuff to do a SAS on it. If I can get my 95 King Cab HB running again I may switch the block from the 2door to my HB. It has sat for about 2 yrs with a non working auto tranny and now the engine wont turn over. I hope it is just that I need a new battery and that one I tried is getting alittle weak. If it wont crank it looks like engine work in the very near future. May just get the HB running and driving and sell it for funds for the SAS and the work on my 93. Thanks for the advice concerning my ride. James Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 27, 2013 Author Share Posted March 27, 2013 Well I finally got to check my MAF on the 86.5 Pathy. It was clean with no buildup. Will check the codes tomorrow. Link to comment Share on other sites More sharing options...
Alkorahil Posted March 27, 2013 Share Posted March 27, 2013 Clean the MAF sensor and make sure the plug contacts are completely free of corrosion. Agreed. The MAF can be nice and clean and the harness connector be the problem as we have seen many times. Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 28, 2013 Author Share Posted March 28, 2013 I will have to check the connector then forgot about the plug. Link to comment Share on other sites More sharing options...
Alkorahil Posted March 28, 2013 Share Posted March 28, 2013 Far be it for me to pimp parts ...........might I also recommend: PART NUMBER: 24079-40F00ENGINE SUB HARNESS$20.39 (NISSAN LIST $32.50) Many can attest on here that this sub harness fix has cleared up this issue for them. It provides a better ground for the MAF harness which may be the cause of your issues based on the symptoms described. Link to comment Share on other sites More sharing options...
Hytekrednek Posted March 28, 2013 Author Share Posted March 28, 2013 Well al righty then. I will be looking into getting that part. This seems to be the only problem with the 86.5 right now that concerns the engine other than finding the damn hoses and stuff. That search was performed well before knowing about you. Again thanks and look for an internet order from the great state of GA coming your way soon. James Link to comment Share on other sites More sharing options...
