96Pathfinder4x4 Posted November 30, 2012 Share Posted November 30, 2012 Has anyone tried it? During my lift, I stressed the sensor wire a bit too much when the block supporting the LCA fell. Result: Using a dremel tool I removed the stock potting compound, stripped back the sheathing, prepped the wires and the terminals, and soldered them. I'm not certain that it's not polarized, since I couldn't find any information. If it doesn't work, I will try swapping the wires. If it does work, I'll get some potting compound and seal it up nicely. 1 Link to comment Share on other sites More sharing options...
rocky2 Posted November 30, 2012 Share Posted November 30, 2012 Good work !!! Glad to see that you're fixing it. That shows some ingenuity. Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted November 30, 2012 Author Share Posted November 30, 2012 Thanks. I prefer to repair/fix/make than buy...as long as I have the time. 1 Link to comment Share on other sites More sharing options...
ramdala Posted December 3, 2012 Share Posted December 3, 2012 Good work !! Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted December 4, 2012 Author Share Posted December 4, 2012 Still awaiting help to bleed the brakes. ABS light is still on, but the brakes go almost to the floor, so I'm still hopeful. After referencing the manual, I didn't know that I had a Load Sensing Valve that needs bled...and that for ABS, I have to disconnect the battery. Will hopefully have an update this weekend. Link to comment Share on other sites More sharing options...
yjnb Posted May 25, 2013 Share Posted May 25, 2013 How did it turn out? James Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted August 8, 2013 Author Share Posted August 8, 2013 Sorry for the late reply. ABS light is still on. I have yet to swap the wires to see if they are directional. I've had other projects take my attention away from my Pathy. I'm planning on getting back to it this weekend or next week. Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted January 22, 2014 Author Share Posted January 22, 2014 Swapped the wires and will test it soon. After the last trip, I think it was overdue. For the record...this is backward. I swapped it. Taped it up and will put on some liquid electrical tape. If it works, golden. If not I'll be heading to the junkyard in hopes of saving $200. Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted January 27, 2014 Author Share Posted January 27, 2014 Put it in and ABS light is still on. Brakes feel better. Will the ABS light reset automatically, or do I need to pull the battery cable to see if the repair was successful? Hooked up backwards, I might have damaged something or blew a fuse? Link to comment Share on other sites More sharing options...
