onefast87 Posted February 27, 2012 Share Posted February 27, 2012 Occasionally i can smell burning oil inside the cab. Now i have inspected the engine bay, there is no sign of oil leaking, ive made sure to check the valve covers. I have no leaks underneath my pathfinder. and as far as i can tell the motor does not smoke out of the exhaust, and it does not appear to burn engine oil.( oil level never goes down) any input would be greatly appreciated. Link to comment Share on other sites More sharing options...
Precise1 Posted February 27, 2012 Share Posted February 27, 2012 No rhyme or reason to it? Stopped, certain speed, place or condition? Hot? Cold? Totally random?? B Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted February 27, 2012 Share Posted February 27, 2012 Check and see if your shifter boots are torn. That could be why you smell it in the cab. Then check to see if your oil pan or rear main seal is leaking on your exhaust's crossover tube. Link to comment Share on other sites More sharing options...
onefast87 Posted February 27, 2012 Author Share Posted February 27, 2012 No rhyme or reason to it? Stopped, certain speed, place or condition? Hot? Cold? Totally random?? B It seems after driving it, when i come to complete stop, and just sit for 5 min i can smell it, but the smell does not last long. Link to comment Share on other sites More sharing options...
onefast87 Posted February 27, 2012 Author Share Posted February 27, 2012 Check and see if your shifter boots are torn. That could be why you smell it in the cab. Then check to see if your oil pan or rear main seal is leaking on your exhaust's crossover tube. thanks for the reply, i will check it as soon as i can. Just snowed like crazy. i will report back after looking at it. Link to comment Share on other sites More sharing options...
Precise1 Posted February 27, 2012 Share Posted February 27, 2012 Yup, makes sense with your answer. With a little luck it is just the oil pan and snugging the 10mm bolts is all that is needed. B Link to comment Share on other sites More sharing options...
