andrewcconti Posted September 29, 2011 Share Posted September 29, 2011 I purchased a pretty clean 1988 Pathfinder with 170k miles this summer for $1100. Having spent most all of its life in CO the truck is very very solid. I had read these are reliable as a clock so I felt ok with putting another $1500. into the truck to get it running well. I have changed jobs and my new job requires I drive to Williamsport, PA from Attleboro, MA (400 miles one way) once a month. Williamsport has a bit of a small mountain range surrounding the city and they are known to get alot of snow, I figured the Pathfinder would be the perfect winter transport. I had a few wet starting issues that a nissan independent was able to track down to a 15 yr old distributor cap that was cracked and arching. (thank's for missing that Meineke). Now to my latest problem... This morning I drove my girl to school and noticed when I went to start the truck a slight hesitation. I drove her to school, stopped to get coffee and went to start it again and it seemed to pause, rumble and then start up like it was struggling to start. I drove it home, shut it off and tried to start it again and it stumbled, stumbled and then eventually started, once running it runs fine. Is this something simple I can check myself? or am I due for a new starter at 170k? If I am in for a new starter any idea what a garage would charge to put one in? I am sooo broke right now. Thanks in advance! Andrew Link to comment Share on other sites More sharing options...
BowTied Posted September 30, 2011 Share Posted September 30, 2011 Is the engine turn over slow at first and then at the last second starts? It could be a starter. It could be a dying battery. WIth the truck off, the battery should be around 12 and half volts. Running 13-14. Link to comment Share on other sites More sharing options...
