PivoArch Posted June 24, 2011 Share Posted June 24, 2011 Hey All, I'm getting ready to buy my OME lift. I'm planning on getting the Springs from Rugged Rocks: OME2928 Heavy Load for the Fronts OME2922 Medium Load for the Rear I seem to recall people having problems with the OME shocks and recommending the KB GR2's and Gas-a-Justs, is that accurate? Are KYB 335035, KYB 335056 and KYB 343379 the correct part numbers for those? Also, I know I need to get new OEM strut mounts and bearings, would anyone happen to know the part numbers for those? Thanks in advance, Link to comment Share on other sites More sharing options...
DesertFox Posted June 24, 2011 Share Posted June 24, 2011 Make sure you put some pictures up ASAP! I'm doing the exact same lift to my Pathy when the funds arrive! Link to comment Share on other sites More sharing options...
PivoArch Posted June 25, 2011 Author Share Posted June 25, 2011 Also, does anyone know the part number for Bilstein shocks for the R50? Link to comment Share on other sites More sharing options...
SilentLamb Posted June 26, 2011 Share Posted June 26, 2011 (edited) I have a 2004 and just recently put in the OME springs and rear shocks. I used the KYB GR-2 struts in the front. The part numbers for the KYBs are: 335032 335033 I think the rear KYB shock part number (343379) is correct. I haven't had any issues with the OME shocks. Edited June 26, 2011 by SilentLamb Link to comment Share on other sites More sharing options...
PivoArch Posted June 29, 2011 Author Share Posted June 29, 2011 Thanks for the part numbers, gonna try to order everything up next week. Still trying to figure out exactly which OEM parts i need for the mounts. Link to comment Share on other sites More sharing options...
devonianwalk Posted June 29, 2011 Share Posted June 29, 2011 Only OEM parts you should need are the strut mounts and bearings. The parts counter will know the part numbers when you tell them what you need. Link to comment Share on other sites More sharing options...
Qx4donald Posted June 29, 2011 Share Posted June 29, 2011 (edited) Hey All, I'm getting ready to buy my OME lift. I'm planning on getting the Springs from Rugged Rocks: OME2928 Heavy Load for the Fronts OME2922 Medium Load for the Rear I seem to recall people having problems with the OME shocks and recommending the KB GR2's and Gas-a-Justs, is that accurate? Are KYB 335035, KYB 335056 and KYB 343379 the correct part numbers for those? Also, I know I need to get new OEM strut mounts and bearings, would anyone happen to know the part numbers for those? Thanks in advance, per the KYB catalog: http://www.kyb.com/catalogs/index.php KYB GR-2 struts: RH=335032, LH=335033 KYB GR-2 shocks: both are 343379 or alternatively KYB Gas-A-Just: both are KG4163 Nissan OEM strut bearing: something along the lines of "54325" Nissan OEM strut mount: something along the lines "54320" *I use "something along the lines of" because some dealerships append their own tracking/serial numbers to the part numbers, but all should have the same "base" number If I were you, I'd bring a copy of the parts list illustration to make sure they order the correct part (to avoid the hassle of 15% restocking fee if THEY order the wrong part) CourtesyParts.com - 1996-2004 Pathfinder front suspension In regards to the rear shocks... I had purchased both the KYB GR-2 (aka Excel) and Gas-A-Justs rear shocks from Amazon.com. Comparing the 2, the Gas-A-Justs had noticably* more resistance in them as far as slowly compressing the GR-2 and Gas-A-Justs (ie. Gas-A-Justs took more strength to push down and comparess compared to the GR-2). I also did a hand-shock comparison, where I'd just momentarily press and release my weight to each shock. Again, the Gas-A-Just provided noticably* more resistance to compress. I went for the Gas-A-Justs, just because they were a little more "heavy duty-ness" to them, compared to the GR-2 rear shocks. *noticably - by this I mean, you can feel the difference. I wouldn't say it was MUCH more different, but enough difference to be able to notice. However, not sure if you're concerned with looks or not, but here's my truck with the white Gas-A-Justs in the rear. The white makes them quite noticable. They only come in white. Edited June 29, 2011 by Qx4donald Link to comment Share on other sites More sharing options...
PivoArch Posted June 30, 2011 Author Share Posted June 30, 2011 Awesome Qx4donald. This is great information and exactly what I have been looking for. I don't think I would mind the white shocks so much. Thanks for the info, now I just need to get the newest recall checked out and I can go about ordering my new suspension. Link to comment Share on other sites More sharing options...
