ahardb0dy
Anatomy of a Nissan ignition lock assembly
Just finished re-keying this ignition lock for my 90 Sentra to match the key for my pathfinder, some guys on a lock picking forum I frequent wanted pics for future reference so I figured I would post them here as well, not sure of what every part is called, I am not a lock smith I am just good at looking at something and figuring out how they work:
front view of assembly showing pin that has to be removed to remove lock cylinder:
rear view showing pin that has to be removed to remove lock cylinder:
2 pins removed:
believe this is the switch that activates the beep when you leave the key in:
removing lock cylinder, pic shows spring on top of lever and hole where one of the pins engages that holds the cylinder in the housing:
lock cylinder removed:
button you press to remove key, and lever?:
part that engages the electrical ignition switch left side,:
lock tumbler showing pins in what would be the no key locked position, 8 wafers:
spacer between lock cylinder and housing:
more in a second
lock housing front:
lock housing rear:
key in showing wafers lined up with outer cylinder, "unlocked":
all parts:
that's it!
I know this is a very old thread, but I am looking to rekey my ignition and was wondering if you had any more information on how those pins were removed. Not all the pictures are showing up over 7 years after the original posting. Do you remember how you were able to get them out? Any help is appreciated. Thanks.
The little pins are removed by drilling a small hole next to each pin, than prying the pin out with a scribe tool or similar tool
Edited by ahardb0dy
