PaMountianbiker Posted March 5, 2011 Share Posted March 5, 2011 well I just fixed my Rock crawler LOL. Cv joint went fine. the tie rod gave me a little trouble:couldn't get the nut off the steering rack. I discovered that my whole diff is loose seems it mounts with two bushings(one on each side) and I have none.Anyone else have an issue like this? Link to comment Share on other sites More sharing options...
synthetic Posted March 5, 2011 Share Posted March 5, 2011 look for energy suspensions website, then find something like builders page, you can have a bushing specially made by them to your specs. same prob on my wd21 annnd on the wd21s it seems my only option cause the carrier and bushings are discontinued. Link to comment Share on other sites More sharing options...
PivoArch Posted March 5, 2011 Share Posted March 5, 2011 You can still get new mounts and bushing from Nissan for the r50's, at least I could for my 02 Pathy. Nissan calls them Front Final Drive Mounting Cushions. Part numbers 54730 and 54710M in the diagram at this link http://www.courtesyparts.com/pathfinder-parts-r50-1996-2004/genuine-nissan-parts/power-train/389-front-final-drive-mounting/-c-4700_4701_4769_4798.html Link to comment Share on other sites More sharing options...
PaMountianbiker Posted March 5, 2011 Author Share Posted March 5, 2011 I love this website Thank you Npora members Link to comment Share on other sites More sharing options...
PaMountianbiker Posted March 7, 2011 Author Share Posted March 7, 2011 Bought my parts to fix this today at my local nissan dealer $140 for both sides doesn't look that hard to change them. Link to comment Share on other sites More sharing options...
PivoArch Posted March 8, 2011 Share Posted March 8, 2011 I'm going to be replacing the whole front diff including the mounts some time in the future, I don't think you are that far from me, but if you'd like I'll let you know when. We could do them both at the same time. I say future, but it may be a few months. Link to comment Share on other sites More sharing options...
PaMountianbiker Posted March 8, 2011 Author Share Posted March 8, 2011 The mounts will be here on thurs and I hope to change them on thurs. nite maybe fri. I will try to get pics but it's awful tight down there. Link to comment Share on other sites More sharing options...
PivoArch Posted March 8, 2011 Share Posted March 8, 2011 If you can get the nut and bolt that go through the bushing out, that would drop the diff and probably allow you an easier time in getting the 8 bolts that hold those brackets to the diff off. Definately let me know if you discover any tips or tricks. Link to comment Share on other sites More sharing options...
PaMountianbiker Posted March 13, 2011 Author Share Posted March 13, 2011 I had to turn up air pressure to get nuts loose and a swivel helped alot it is worth getting one.Be careful putting the bolts back in the front diff the aluminum threads strip out very easy I have to run bolts through 2 of them now Link to comment Share on other sites More sharing options...
PivoArch Posted March 14, 2011 Share Posted March 14, 2011 Noted, thanks for the heads up. Link to comment Share on other sites More sharing options...
ascdesigns Posted December 8, 2011 Share Posted December 8, 2011 Hate to resurrect an old thread, but I'm about to do this next weekend and could use some more "beta". Can I ask if you had to disconnect either the CV axles and/or front driveshaft to be able to replace these? Also, are the struts in the way at all? Thanks, Al Link to comment Share on other sites More sharing options...
