JamesRich Posted January 5, 2012 Share Posted January 5, 2012 Tinkered with the engine a bit more. I have to take the oil pan back off because I forgot to RTV the rear main seal housing. Got too far ahead of myself. Looks Great! James Link to comment Share on other sites More sharing options...
RJSquirrel Posted January 5, 2012 Share Posted January 5, 2012 Finished the drivers side frame rust repairs. Awaiting more Internal frame coating from Eastwood to arrive, so the truly messy part of the rust repair job can commence: Painting the frame. Ugh. Still no snow(read: road salt) in Chicago. If this is what global warming does, I'm all in favor of it. Link to comment Share on other sites More sharing options...
1994SEV6 Posted January 5, 2012 Share Posted January 5, 2012 (edited) Finished the drivers side frame rust repairs. Awaiting more Internal frame coating from Eastwood to arrive, so the truly messy part of the rust repair job can commence: Painting the frame. Ugh. Still no snow(read: road salt) in Chicago. If this is what global warming does, I'm all in favor of it. too bad there is no such thing as global warming, only climate change. Tinkered with the engine a bit more. I have to take the oil pan back off because I forgot to RTV the rear main seal housing. Got too far ahead of myself. very snazzy. Edited January 5, 2012 by 1994SEV6 Link to comment Share on other sites More sharing options...
Towncivilian Posted January 5, 2012 Share Posted January 5, 2012 Aired up the tires, they were at 26 psi. Filled em up to 32. Gotta check the spare. The TPMS light in my mom's Altima went off last night. The tires were at 20 psi. I filled em up to 32, drives over 9000 times better now. I was also too lazy to check the spare, but it was like 40 degrees outside and it was relatively late. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 5, 2012 Share Posted January 5, 2012 I thanked my pathfinder for having a working defogger. Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 5, 2012 Share Posted January 5, 2012 Finally got around to replacing the back up light switch. Back up lights still dont work. Cried. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 6, 2012 Share Posted January 6, 2012 Finally got around to replacing the back up light switch. Back up lights still dont work. Cried. sometime the link inside the tranny gets worn and won't reach the switch. same thing happened to me -the cries... pushing the switch by hand turned the lights on but it would not light when screwed in. It had a metal button so zapped it with the MIG so it was taller and my problem was solved. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 6, 2012 Share Posted January 6, 2012 Today I Cleaned my K&N air filter. It was pretty bad, The dirty water in the sink was from the second rinse. This is probably the last time I will wash and re-oil this filter as I will likely be MPFI before it gets dirty again. Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 6, 2012 Share Posted January 6, 2012 sometime the link inside the tranny gets worn and won't reach the switch. same thing happened to me -the cries... pushing the switch by hand turned the lights on but it would not light when screwed in. It had a metal button so zapped it with the MIG so it was taller and my problem was solved. I had seen that in a thread when I searched. I'm gonna pull it out again this weekend, make 100% sure it works by hand (I was working solo when I put it in) and then see if my buddy will let me use his welder to do the same thing you did. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 6, 2012 Share Posted January 6, 2012 I had seen that in a thread when I searched. I'm gonna pull it out again this weekend, make 100% sure it works by hand (I was working solo when I put it in) and then see if my buddy will let me use his welder to do the same thing you did. The button is hollow so put a vise grip on it to steal the heat and don't zap it too hard or you will put a hole in it. You may have to quench between really short zaps to get enough build up on it. Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 6, 2012 Share Posted January 6, 2012 The button is hollow so put a vise grip on it to steal the heat and don't zap it too hard or you will put a hole in it. You may have to quench between really short zaps to get enough build up on it. Perfect, thanks for the tip. Link to comment Share on other sites More sharing options...
nismothunder Posted January 6, 2012 Share Posted January 6, 2012 Threw a bottle at it and yelled 'why you no start!?!' Link to comment Share on other sites More sharing options...
lint Posted January 6, 2012 Share Posted January 6, 2012 Found an large, empty, and freshly iced parking lot.... :laugh: :laugh: :laugh: Link to comment Share on other sites More sharing options...
SchizophrenicMC Posted January 6, 2012 Share Posted January 6, 2012 Took my sister and her friend home, tried to find salvage yards with black Pathfinders. Struggling to decide whether or not to mount a cupholder to the passenger side dash. Link to comment Share on other sites More sharing options...
1994SEV6 Posted January 6, 2012 Share Posted January 6, 2012 Took my sister and her friend home, tried to find salvage yards with black Pathfinders. Struggling to decide whether or not to mount a cupholder to the passenger side dash. The cupholder situation is hard. Nothing really work. The obvious solutions turn out badly. The only real solutions are to get a JGC console, or some other really rare accessories. I think the JGC is a very good match, but it's not perfect. The other accessories I mentioned are cupholders that go into the DIN slot or..something else I forgot. There are some creative solutions out there. Here's my personal favorite Link to comment Share on other sites More sharing options...
5523Pathfinder Posted January 6, 2012 Share Posted January 6, 2012 (edited) Changed the front and rear diff fluids and the transfer case fluid. Had to make sure nothing got in from playing in the water! All was good. Also cleaned his windows and changed the both rear brake light bulbs. Edited January 6, 2012 by 5523Pathfinder Link to comment Share on other sites More sharing options...
ANDY Posted January 6, 2012 Share Posted January 6, 2012 . Struggling to decide whether or not to mount a cupholder to the passenger side dash. i seen in this heep at work some pvc pipe with a end cap screwed into the floor board with a sheet metal screw came out pretty good i thought of doing the same thing sorry i cant gind any pics but hope you get the idea Link to comment Share on other sites More sharing options...
nunya Posted January 7, 2012 Share Posted January 7, 2012 This is probably the last time I will wash and re-oil this filter as I will likely be MPFI before it gets dirty again. bastage and your fancy MPFI swap... He got a bath and a good frame hosing/rinsing today. Amazing how much salt builds up over so little being needed on the roads now tomorow I might actually work on one of the many lingering half done projects... Link to comment Share on other sites More sharing options...
SchizophrenicMC Posted January 7, 2012 Share Posted January 7, 2012 The cupholder situation is hard. Nothing really work. The obvious solutions turn out badly. The only real solutions are to get a JGC console, or some other really rare accessories. I think the JGC is a very good match, but it's not perfect. The other accessories I mentioned are cupholders that go into the DIN slot or..something else I forgot. There are some creative solutions out there. Here's my personal favorite I have a 90, so the passenger-side dash is nearly vertical and flat (whoo, 80s interior) and I was thinking of either adhering or bolting 2 of these to it. They'd look okay closed on the dash, I think, and I'm fairly certain the material could hold the weight of a drink. Regardless, I'd probably reinforce it anyway. What really has me wondering is rear cupholders. Some buddies and I plan on road-tripping the Pathy up to Colorado or Utah up here in a few months, so we'll have the three of us in the truck. I considered the rear door panels, but the arm rests get in the way, and there's probably not enough room back there anyway. I actually have a 95-98 Altima Half-DIN cupholder, but there's nowhere to put it in a 90 Pathfinder, and it gets in the way of the shifter, anyway. (whoo, 5-speed ) I'll save it for my next S-chassis or Z... Always wanted to figure out how to get one into a Z32... Link to comment Share on other sites More sharing options...
Nefarious Posted January 7, 2012 Share Posted January 7, 2012 Installed 5" round Phase Linear speakers I had sitting around in the front doors and some 5"x7" MTX Thunders in the rear headliner. Muuuuuch better! Amp and sub go in tomorrow and now it is officially comfortable to drive again. Link to comment Share on other sites More sharing options...
Dowser Posted January 7, 2012 Share Posted January 7, 2012 (edited) Cut and ground the Steering stabilizer bracket off my Centerlink to make room for the Rancho version. YA for having 2 hours to "myself" to play with the new Dremel, and BOO for having to use that 2 hours to play with an inanimate object and not myself. Edited January 7, 2012 by Dowser Link to comment Share on other sites More sharing options...
nunya Posted January 7, 2012 Share Posted January 7, 2012 You have 2 hands (and I have the Rancho single shock stabalizer and didn't cut the tabs off the CL ) Link to comment Share on other sites More sharing options...
ANDY Posted January 7, 2012 Share Posted January 7, 2012 installed some silverstars after work now i need to adjust my lights cause i messed with them with the old bulbs Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted January 7, 2012 Share Posted January 7, 2012 Looked at swapping my turn signals with the side markers...harder than i thought. Installed the left mud flap in the passenger rear footwell(damn rust). I might relocate the right one tomoro...for asthetics only of course. Link to comment Share on other sites More sharing options...
nunya Posted January 7, 2012 Share Posted January 7, 2012 Took my side steps off so I can start re-enforcing them as I like the factory rails (though I almost never use them). Add another project to the list of things that won't be finished any time soon Link to comment Share on other sites More sharing options...
