Kyle94 Posted September 9, 2013 Share Posted September 9, 2013 Got halfway through the install of new rotors and pads... All was going well until I ran into a really badly seized caliper slide pin. Have to work at 1130am tomorrow so I guesss I'll be getting up early. Checked the others and they're fine... Thinking I may just want to get a new bracket and two slide pins? Ugh. Being stuck with one car with a bad wheel bearing and one with no brakes sucks!! Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 9, 2013 Share Posted September 9, 2013 You should be able to get the pin out, use a punch if you have to. Clean all the old grease off ( probably why it is stuck), make sure to use new silicone grease on the pins. I had this stuff called sylglide I think it was, got it from Napa, Link to comment Share on other sites More sharing options...
Towncivilian Posted September 9, 2013 Share Posted September 9, 2013 Yep, Syl-Glide is great. NAPA sells it. Link to comment Share on other sites More sharing options...
Kyle94 Posted September 9, 2013 Share Posted September 9, 2013 Went down to pick up a new one.... Cant get it till tomorrow morning. But now i have bigger problems. I can't use the 1/2" drive ratchet I was using. The jack. And a few other things. Cuz someone wants to be an a$$.... Link to comment Share on other sites More sharing options...
Trogdor636 Posted September 9, 2013 Share Posted September 9, 2013 Time to buy your own tools. Start with a small basic set, add stuff you need as you go along. Then you don't have to rely on others.<br /><br /> Link to comment Share on other sites More sharing options...
Kyle94 Posted September 9, 2013 Share Posted September 9, 2013 I have a small basic craftsmen set. I guess I'll be going to buy a ratchet and maybe a hammer after work today. Just silly if you ask me. And I'll use the stock Nissan jack. Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 9, 2013 Share Posted September 9, 2013 Well once you get the stuck pin out you should only need a standard 3/8" ratchet to get it apart the next time, just make sure to grease the slide pins. The craftsman set should have a 3/8" ratchet in it. I usually will put the ratchet with socket on the bolt and give it a whack with my palm and that is enough to brake it free, no need to tighten it to death. Link to comment Share on other sites More sharing options...
Kyle94 Posted September 9, 2013 Share Posted September 9, 2013 I have a 3/8" ratchet. But the socket I have to take off the bracket pin won't come out with it on the truck.) Is for a 1/2" drive. It's okay. I got a 25$ gift card to Wal-Mart. So I'll go buy a cheapy for now. Lolol. after that I should be set Link to comment Share on other sites More sharing options...
Kyle94 Posted September 10, 2013 Share Posted September 10, 2013 (edited) Rachet bought. order for the caliper bracket canceled. got the pin out....... : Can you tell it's bent? I don't know if i did that when i was beating on it (finally stuck it in a vice and twisted it out.....) or if pushing on the brakes did it. But i hope once it's all back together it won't shimmy shake or wobble down the road or when stopping. it was bad.... So for now it sits up in the air, three legged. Waiting on two slide pins boots (why the eff don't new pins come with new boots!?) Also figured out (never looked before) that lego's and my 31x10.50x15's clear the strut bottom by just a little. And that the drivers side rubs when it get's stuffed (front) while playing around in the sand at the beach... hahah. Edited September 10, 2013 by Kyle94 Link to comment Share on other sites More sharing options...
Aegis Posted September 11, 2013 Share Posted September 11, 2013 Today my parts came in the mail so I went crazy putting stuff on. Until I got the rear window struts that is. I got the cowl panel piece on nicely, but then when I got to removing the rear window struts from the window, I can't figure it out. The top bracket end is super easy, just two 10mm nuts, but the bottom part at the bottom won't come off. It is the factory Nissan strut with no external clip on the socket to pry it off with. I tried simply spinning the ball part out as well, but the whole assembly the ball is screwed into turns and I can't think of a way to stop it from spinning. The only thing I've come up with so far would just be to cut it off, which would be okay since I have new parts, but that would leave a stud inside the rear window I still couldn't get out. Does anyone have any experience with this? I wouldn't have thought it would be this hard since it was quite simple to do the litigate struts. Link to comment Share on other sites More sharing options...
adamzan Posted September 11, 2013 Share Posted September 11, 2013 You need to hold the black cap thing on the outside of the window from spinning, then use a 10mm wrench and it should unscrew from it. Mine were tight also. Link to comment Share on other sites More sharing options...
Aegis Posted September 11, 2013 Share Posted September 11, 2013 Yeah, that is what I thought. I tried holding it with my fingers and a jar lid opener grip thing but I just can't keep grip on it. Maybe I can thing of something eventually. Thanks for confirming my suspicion though. Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 11, 2013 Share Posted September 11, 2013 Was going to tell you that you can use a drill bit slightly smaller than the size of the hole the slide pins go in to clean the holes out Link to comment Share on other sites More sharing options...
vagabond Posted September 11, 2013 Share Posted September 11, 2013 flushed the brake system out on the 88 might do the 94 tomorrow Link to comment Share on other sites More sharing options...
adamzan Posted September 12, 2013 Share Posted September 12, 2013 New rear brakes and shocks installed tonight. Link to comment Share on other sites More sharing options...
cvdloc Posted September 12, 2013 Share Posted September 12, 2013 Broke a cv shaft story in general forums Link to comment Share on other sites More sharing options...
Aegis Posted September 14, 2013 Share Posted September 14, 2013 Took an hour and a half drive one way to buy manual locking hubs, then an hour and a half back and picked up a roof basket. Hopefully tomorrow I can find the time to actually do some work. Still need to try and get my rear window struts sorted out as well. Link to comment Share on other sites More sharing options...
kidscollegefund Posted September 15, 2013 Share Posted September 15, 2013 Spray painted over the Yakima logo on my roof rack....they aren't paying me. 2 Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 15, 2013 Share Posted September 15, 2013 Drove it to go out for dinner, dam H4 headlights are bright as hell !!! Link to comment Share on other sites More sharing options...
theexbrit Posted September 15, 2013 Share Posted September 15, 2013 Finished (sort of) fitting the XJ winch bumper to Old Green.................... 1 Link to comment Share on other sites More sharing options...
sroeser01 Posted September 15, 2013 Share Posted September 15, 2013 ^^^ dying to see this. Hand on the trigger to order one. Thanks exbrit for being the prototype finder 1 Link to comment Share on other sites More sharing options...
theexbrit Posted September 15, 2013 Share Posted September 15, 2013 It's nearly finished, I have an LED light bar to go on & a vented skid plate to go from the bottom of the bumper down to the base of the radiator, etc, for protection. I'm also going to make the side pieces where the bumper ends a little more "finished". It's great because it's a very small bumper & weighs about 100lbs, I didn't lose any front height because of the weight. 2 Link to comment Share on other sites More sharing options...
kidscollegefund Posted September 15, 2013 Share Posted September 15, 2013 F-me that is dead sexy! 1 Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 15, 2013 Share Posted September 15, 2013 Nice ! looks good 1 Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 15, 2013 Share Posted September 15, 2013 Just finished installing a 4 ch. amp that I traded a guy 22 old car audio magazines for, Cerwin Vega 60 x 4, running it in a 3 ch. mode, made a board to mount it on and also installed 3 fans controlled by a relay to move air across the heat sink, sounds pretty good, nothing fancy to look at but that's fine just wanted to get it in. 1 Link to comment Share on other sites More sharing options...
