Citron Posted September 5, 2017 Share Posted September 5, 2017 Why monthly? My manual says nothing about that. Link to comment Share on other sites More sharing options...
mjotrainbrain Posted September 5, 2017 Share Posted September 5, 2017 Why monthly? My manual says nothing about that. I don't know why, just what the manual says. Mine's a Rough Country. Can't remember exactly what it says without looking, but it's something like disengage clutch and pull out 5ft, then engage clutch and spool out 15ft, then spool in 20ft. 1 Link to comment Share on other sites More sharing options...
Mrelcocko Posted September 5, 2017 Share Posted September 5, 2017 Changed the front pads. Looked like there was still a fair bit left on them, but when compared to the new ones they were waaaaaay down. Only had to fight one stuck slide pin. However, I did notice that one of the camber bolts was sheared off, which is 'interesting' considering I just got an alignment a couple weeks ago and haven't inspected super thoroughly since...hmm...Gonna do the same this coming weekend. Sent from my Z836BL using Tapatalk Link to comment Share on other sites More sharing options...
Charlie_Brown Posted September 6, 2017 Share Posted September 6, 2017 Why monthly? My manual says nothing about that. Monthly to keep fears properly lubed and ready to go. Too much sitting around is bad for the motor and gears 2 Link to comment Share on other sites More sharing options...
Citron Posted September 6, 2017 Share Posted September 6, 2017 Noticed that both the Titan and wd21 are leaking gear oil from the front diff. The pathy looks like it is coming from the drain plug, but it is as tight as possible, so I am going to spray it off with brake kleen and see if the drip comes back. Ordered a pinion seal for the Titan. Link to comment Share on other sites More sharing options...
Charlie_Brown Posted September 6, 2017 Share Posted September 6, 2017 Primed and painted the spindle so it can be nice and pretty hidden behind the tire lol. Pointless but whatever, looks good. 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted September 7, 2017 Share Posted September 7, 2017 Ordered my winch and got a free cover in the process, should be here next week. Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 7, 2017 Share Posted September 7, 2017 (edited) Got the crank in and got some measurements for the bearings. Times like this I wished I had a bore gauge. Rods look good but I'm concerned about the mains. 1 and 4 are within range loose specifically 0.051 but 2 and 3 are out at 0.078 limit is 0.090 so I'm good in that aspect. I'm wondering if it's because I'm not getting a good torque reading with me doing it upside down. Also number 4 bearings were stuck (snug fit) to the crank when I removed it. Sent from my SAMSUNG-SM-N920A using Tapatalk Edited September 7, 2017 by Cuong Nguyen 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted September 7, 2017 Share Posted September 7, 2017 Got the springs trimmed to reduce my lift a bit, and the new shocks installed Sent from my SM-G920V using Tapatalk 1 Link to comment Share on other sites More sharing options...
neilca Posted September 7, 2017 Share Posted September 7, 2017 Got the springs trimmed to reduce my lift a bit, and the new shocks installed Sent from my SM-G920V using Tapatalk Uh is that rubber bushing on the ground out of place? Link to comment Share on other sites More sharing options...
RCWD21 Posted September 7, 2017 Share Posted September 7, 2017 Uh is that rubber bushing on the ground out of place?No that's from the old set of shocks Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted September 8, 2017 Share Posted September 8, 2017 Got some drop down brackets for my e-brake fabbed up and installed, they're not pretty but they'll do the job just fine. Now I have a functioning e-brake again, next up is trimming the exhaust, rebuilding the front calipers, and leveling off the front end Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
Charlie_Brown Posted September 10, 2017 Share Posted September 10, 2017 Replaced upper balljoint on passenger side and clearcoated spindle. Seperated tie rod and began disassembly of the hub so I can torque the balljoint down. 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted September 11, 2017 Share Posted September 11, 2017 Rebuilt the front calipers and installed new brake pads, tomorrow is rear brakes.. Sent from my SM-G920V using Tapatalk 1 Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 11, 2017 Share Posted September 11, 2017 Hooked the battery to a tender. Sent from my SAMSUNG-SM-N920A using Tapatalk 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 11, 2017 Share Posted September 11, 2017 New swaybar links on the front. Old bushings didn't look too bad but had probably lost most of their flexibility over the years, and both bolts had worn maybe 1/3 of the way through on the LCAs. 1 Link to comment Share on other sites More sharing options...
Mrelcocko Posted September 11, 2017 Share Posted September 11, 2017 Hooked the battery to a tender. Sent from my SAMSUNG-SM-N920A using Tapatalk Lol! Sent from my Z836BL using Tapatalk Link to comment Share on other sites More sharing options...
Charlie_Brown Posted September 11, 2017 Share Posted September 11, 2017 Installed idler arm brace, took off brake pad assembly after messing with frozed bolts and snapped my only Alan wrench socket I had of correct size turning out the seized bolts to the &^%*ing hub. Got all but two free. Last of clear coating on spindle done so control arm should be going on soon. Or in short I fought bolts till they broke my tools leaving me dead for the day. 1 Link to comment Share on other sites More sharing options...
Nissanland Posted September 13, 2017 Share Posted September 13, 2017 Got it back from the guy who was going 2 paint up for me. That was months ago, so yep I never sold her. And still needs paint lol Link to comment Share on other sites More sharing options...
RCWD21 Posted September 14, 2017 Share Posted September 14, 2017 Drove 2 hours and got all the metal I'll need to build my front bumper, now I just need to find out how I'm gonna get it all welded up. My winch will be here tomorrow so I'm super excited about that Sent from my SM-G920V using Tapatalk 3 Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 15, 2017 Share Posted September 15, 2017 Bottom end is installed. Time to Check over the new oil pump and wash out all the crud in the oil pan. Sent from my SAMSUNG-SM-N920A using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted September 15, 2017 Share Posted September 15, 2017 Got the foam board for templates, just have to wait til Monday to have the winch delivered now Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 15, 2017 Share Posted September 15, 2017 Got the foam board for templates, just have to wait til Monday to have the winch delivered now Sent from my SM-G920V using Tapatalk I take it foam was easier for you to get vs cardboard? Sent from my SAMSUNG-SM-N920A using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted September 16, 2017 Share Posted September 16, 2017 I take it foam was easier for you to get vs cardboard? Sent from my SAMSUNG-SM-N920A using Tapatalk I went to 5 different places and nobody had any, it had already been crushed... so I just went the easy route and got some foam board from the $ store. Sent from my SM-G920V using Tapatalk 2 Link to comment Share on other sites More sharing options...
Mrelcocko Posted September 16, 2017 Share Posted September 16, 2017 Took some 3M Perfect It Compound and buffed my headlights,blinker and fog lights. out I got a pair of headlights off a 2000 QX4 from my local pull a part and installed them on my 97. Perfect fit just had to rewire the connections. They look brand new. Sent from my SM-S337TL using Tapatalk 2 Link to comment Share on other sites More sharing options...
