vagabond Posted January 20, 2017 Share Posted January 20, 2017 (edited) the guy I bought it from had 2 a 95 with some left frt body damage and the 88. got them both for 1350.00 pulled the fender, hood, grill, frt bumper off my 94 with the bad engine luckily same color, and mama likes the auto tranny better then the 5 spd. been driving the 95 for a month now and it runs sweet Edited January 20, 2017 by vagabond Link to comment Share on other sites More sharing options...
mickmutante Posted January 20, 2017 Share Posted January 20, 2017 Changed the 4x4 green light indicator in the dashboard... lost 2 bolts during the process... 1 Link to comment Share on other sites More sharing options...
LittleFR Posted January 24, 2017 Share Posted January 24, 2017 Cleaned out my soured work uniforms out of the back seat. Bought a gas getter cavalier for $500 that needed wheel bearings and haven't driven The Pathy to work in a couple weeks. It was smelling ripe! 2 Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 24, 2017 Share Posted January 24, 2017 Tested my reversed drag link and it was a definite no-go. Put the original back in. I need to make a new drag link as it is too short for my liking. Also I need to readjust it as my steering wheel is off centered. I get to drive it again so I'm happy. 2 Link to comment Share on other sites More sharing options...
CO_pathfinder Posted January 25, 2017 Share Posted January 25, 2017 Some new noises coming from my Pathfinder but I can't tell what they are because they only occur while I'm driving. First noise is a slight grinding/metal on metal rubbing sound when I turn the wheels to the left, usually between 10-30 mph. Wheel bearing/hub? Second noise is a very similar noise, almost like a bad bearing, that only occurs in 3rd gear at around 3k rpm (haven't noted the speed).. How do I check my wheel bearings in my own driveway? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 26, 2017 Share Posted January 26, 2017 Some new noises coming from my Pathfinder but I can't tell what they are because they only occur while I'm driving. First noise is a slight grinding/metal on metal rubbing sound when I turn the wheels to the left, usually between 10-30 mph. Wheel bearing/hub? Second noise is a very similar noise, almost like a bad bearing, that only occurs in 3rd gear at around 3k rpm (haven't noted the speed).. How do I check my wheel bearings in my own driveway? Not rpm dependent? Only when turning? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 26, 2017 Share Posted January 26, 2017 Replaced the busted clogged cat converter. 300 dollars. Ouch. 1 Link to comment Share on other sites More sharing options...
Backpacker Posted January 26, 2017 Share Posted January 26, 2017 Some new noises coming from my Pathfinder but I can't tell what they are because they only occur while I'm driving. First noise is a slight grinding/metal on metal rubbing sound when I turn the wheels to the left, usually between 10-30 mph. Wheel bearing/hub? Second noise is a very similar noise, almost like a bad bearing, that only occurs in 3rd gear at around 3k rpm (haven't noted the speed).. How do I check my wheel bearings in my own driveway? Jack the tire up, grab grab the wheel by 3 and 9 o'clock and wiggle back and forth. Then repeat but at 12 and 6. It shouldn't have too much play in it. If it's loose the bearing is most likely bad. Check all four, and if one is bad it will probably be looser than the others. The only other way I know of to check them would be pulling them out and cleaning/checking them for wear. At that point though you might as well just replace them. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DcrPrz Posted January 27, 2017 Share Posted January 27, 2017 (edited) Gave old Blue a wash and finally got those rims on. 2003 Frontier 15x7's. Just need to get some center caps. Edited January 27, 2017 by DcrPrz 5 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted January 27, 2017 Share Posted January 27, 2017 Wow, that is super clean!!! Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted January 27, 2017 Share Posted January 27, 2017 Removed the rusted out secondary air system, noticed the brake master cylinder was leaking, and put a new one in. Link to comment Share on other sites More sharing options...
Cornpone99 Posted January 27, 2017 Share Posted January 27, 2017 Got my flurey's skid plates on New plugs wires and distributor Sent from my iPhone using Tapatalk 2 Link to comment Share on other sites More sharing options...
Backpacker Posted January 28, 2017 Share Posted January 28, 2017 Finally got her in the air so I could get proper leverage for the trans bolt. Took a 4 foot cheater to break loose! Replaced the inner shift boot and topped it off through the shifter with redline. Next time I'm doing the whole job through the shifter. Someone on here said it took ages for the oil to seep through the shifter hole, but mine ate up a quart and a half in no time. Maybe they didn't pull it out all the way. Thoughts on this drain plug? The old oil was the blackest gear oi I've ever seen, I don't know how old the fluid was. Truck has 128k mi and it could have very well been the original oil. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted January 28, 2017 Share Posted January 28, 2017 As long as there isn't chunks of bearing on the plug it's fine. The black fuzz is normal. Yeah, I do the whole deal through the shifter. They may have had the little bushing slip off the end of the shifter and block the hole. 1 Link to comment Share on other sites More sharing options...
Citron Posted January 28, 2017 Share Posted January 28, 2017 Having metal particles on the magnet isn't unusual. It doesn't look excessive to me. The only concerning part is that large wire looking piece. Usually, it is just fine particles like all of the rest. Personally, I wouldn't worry too much about it though. Link to comment Share on other sites More sharing options...
Backpacker Posted January 28, 2017 Share Posted January 28, 2017 (edited) Having metal particles on the magnet isn't unusual. It doesn't look excessive to me. The only concerning part is that large wire looking piece. Usually, it is just fine particles like all of the rest. Personally, I wouldn't worry too much about it though. Wire is probably from the oil catch pan, it was a raisable shop style one with a drain. The bolt dropped onto it and probably picked it up there. Sent from my iPhone using Tapatalk Edited January 28, 2017 by Backpacker Link to comment Share on other sites More sharing options...
Citron Posted January 28, 2017 Share Posted January 28, 2017 Wire is probably from the oil catch pan, it was a raisable shop style one with a drain. The bolt dropped onto it and probably picked it up there. Sent from my iPhone using Tapatalk No worries then. Link to comment Share on other sites More sharing options...
vagabond Posted January 29, 2017 Share Posted January 29, 2017 slowly taking off the old blue window tint off the white 88, still have do the door windows, and almost done with the rear hatch glass. Sure looks alot better Link to comment Share on other sites More sharing options...
dirtbike23 Posted January 29, 2017 Share Posted January 29, 2017 (edited) fender trimming how she looks in 32s Edited January 29, 2017 by dirtbike23 3 Link to comment Share on other sites More sharing options...
dirtbike23 Posted January 29, 2017 Share Posted January 29, 2017 new rad, new water pump, after couple of days head gasket leaks....had to take off head and replaced. 3 Link to comment Share on other sites More sharing options...
Mrelcocko Posted January 30, 2017 Share Posted January 30, 2017 Heat wasn't getting hot like it should in my QX4 so installed new thermostat and walla it's a furnace now. Changed the oil and air filter in my QX4 and Pathy along with topping off all fluids. Today was a great day. Sent from my SM-G530T using Tapatalk 1 Link to comment Share on other sites More sharing options...
Charlie_Brown Posted January 30, 2017 Share Posted January 30, 2017 Finally got the vg33 for 400$ last weekend, ECU and all. After taking off alt, pwr steering, A/C and starter i unbolted the block from the tranny in vg30 with a lot of frustration. To many damn bolts on there, just when you think you got them all you find another. To add to the frustration the truck is sitting at a bit of a downward angle and my shocks are blown. To say I had zero room is a drastic understatement Link to comment Share on other sites More sharing options...
Charlie_Brown Posted January 30, 2017 Share Posted January 30, 2017 new rad, new water pump, after couple of days head gasket leaks....had to take off head and replaced. Wait straight 6? What engine are you running? I didn't know VGs ever went straight 6 Link to comment Share on other sites More sharing options...
SpecialWarr Posted January 30, 2017 Share Posted January 30, 2017 I spent most of Saturday guesstimating, cutting out, and preping steel bits for a long overdue frame repair. Passenger side just in front of the rear wheel, over the trailing arm bracket (inside and outside) and the bottom section from the bracket forwards to the crossmember and a small reinforcement for the body mount. In total, 6 separate pieces of cold rolled 1018, cut, trimmed, fitted, deburred, sanded, cleaned, tacked in place and welded on after 2 hours of rust removal with a cordless drill and a wire wheel ( that was all that I had other than a 4" square piece of sand paper).... Two days later and I am still sore from all of that.... didn't take a single photo either. 1 Link to comment Share on other sites More sharing options...
RIPB.88 Posted January 30, 2017 Share Posted January 30, 2017 Wait straight 6? What engine are you running? I didn't know VGs ever went straight 6 Thats a 4 Banger Link to comment Share on other sites More sharing options...
