RedPath88 Posted January 15, 2015 Share Posted January 15, 2015 Did yours have a lock actuator already? Mine doesn't and neither did Mr.510's. Sure did. Link to comment Share on other sites More sharing options...
RF600 Posted January 15, 2015 Share Posted January 15, 2015 (edited) My alt figured it would die on me today. I managed to get to the parts store before the battery completely died. I replaced the battery also. I'm glad these are pretty easy to work on. I changed the alt out in the dark. I did have a drop light though. The way I look at it, I own the vehicle, so no payment. Edited January 15, 2015 by RF600 Link to comment Share on other sites More sharing options...
pathyguy87 Posted January 15, 2015 Share Posted January 15, 2015 Strange new mystery. My E-brake light stays on no matter what, but when the E-brake is actually pulled, the light gets marginally brighter. Any ideas? I checked what I think were all of the connections with an ohm-meter and no issues Make sure your interlock switch is in the off position. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 15, 2015 Share Posted January 15, 2015 CO, check your brake fluid level. My BRAKE light and one other light (battery?) came on a couple times when my brake master was leaking. More brake fluid made the lights go away until the fluid leaked back out again. Doesn't sound like you've got both lights on, but it wouldn't hurt to rule out. Link to comment Share on other sites More sharing options...
jamba Posted January 15, 2015 Share Posted January 15, 2015 Cursed my lights. There has become a delay when i put lights on. Sometimes several minutes. Hi beam works instantly but low has this odd delay.. Link to comment Share on other sites More sharing options...
PHR Posted January 16, 2015 Share Posted January 16, 2015 Cursed my lights. There has become a delay when i put lights on. Sometimes several minutes. Hi beam works instantly but low has this odd delay.. Take a look at this, for me the problem started with a delay when I was turning high beam on. That was the solution: #4193 Philippe. Link to comment Share on other sites More sharing options...
PHR Posted January 16, 2015 Share Posted January 16, 2015 And don't forget to thanks the man above. The post above yours I mean. Ph. Link to comment Share on other sites More sharing options...
JohnnyGIxxer Posted January 16, 2015 Share Posted January 16, 2015 Hung a new alternator today. It's been a nightmare. First off the front bolt broke off so I had to drill it to use a reverser. After an eternity of drilling I stuck the reverser in and tried to extract the bolt. The reverser broke inside the pilot hole. Grrrrrr. Had to grind that smooth and drill that out to get the hole back that I stared with. Lol. Managed to drill out the front bolt hole and then drilled the tread out of the rear bolt hole so I could use one long through bolt like it should be. Now I can't find my fan pully. Been a crazy evening. Link to comment Share on other sites More sharing options...
jamba Posted January 16, 2015 Share Posted January 16, 2015 Take a look at this, for me the problem started with a delay when I was turning high beam on. That was the solution: #4193 Philippe. THANKS! I was just appealing here... -i should have asked about problem on another topic. -But it's solved now. Thanks you, this is a great forum Link to comment Share on other sites More sharing options...
CDN_S4 Posted January 17, 2015 Share Posted January 17, 2015 Ordered LEDs to swap the gauges and center console out, and ordered another (this time the correct - for those that have been keeping track) set of OME rear MD springs. Link to comment Share on other sites More sharing options...
Craig1902 Posted January 17, 2015 Share Posted January 17, 2015 Front wheel bearings replaced and steering damper installed Link to comment Share on other sites More sharing options...
SkiBumBrian Posted January 17, 2015 Share Posted January 17, 2015 Strange new mystery. My E-brake light stays on no matter what, but when the E-brake is actually pulled, the light gets marginally brighter. Any ideas? I checked what I think were all of the connections with an ohm-meter and no issuesCouple of weeks ago my ebrake light was coming on, then going out. Then a few days later the ABS light joined in and they stayed on. Checked the fluid and it was above the MIN line but added some, problem solved. Where did the fluid go? I guess if it is not just worn pads I will find that out too... Link to comment Share on other sites More sharing options...
Harbinger Posted January 17, 2015 Share Posted January 17, 2015 (edited) Built a switch panel that deletes the ash tray today. Built it out of some scrap aluminum, think it was 10 gauge, but might be 12. Need to wire up the switches still, and find reasons to fill the other three spots! Edited January 17, 2015 by Harbinger Link to comment Share on other sites More sharing options...
94 Pathy Posted January 17, 2015 Share Posted January 17, 2015 Just finished replacing the fuel lines/hoses that burnt from the heat & fumes from the hole in the header. Still not going to drive Pathy until headers are replaced. Don't need it going up in flames AGAIN. Hope to order OBX stainless headers in a week or two. 1 Link to comment Share on other sites More sharing options...
Nefarious Posted January 18, 2015 Share Posted January 18, 2015 Just finished installing my HID conversion on the WD21. Low and high beam are working and now I just need to aim them properly So much better ! Now the headlights are powered through a relay and converted to HID with proper conversion housings. Never will I complain about my trucks lighting again. Link to comment Share on other sites More sharing options...
adamzan Posted January 18, 2015 Share Posted January 18, 2015 I hate HID's. I don't see how they are any better, the color of the light makes it impossible for me to see in the rain (having driven several vehicles with factory and aftermarket setups). 1 Link to comment Share on other sites More sharing options...
CNAM Posted January 18, 2015 Share Posted January 18, 2015 HID's, LED's... Love 'em all. Link to comment Share on other sites More sharing options...
Nefarious Posted January 18, 2015 Share Posted January 18, 2015 (edited) I run 4300k hid colour, which is the only factory and legal colour and has the best visibility of any of the headlight options per lumen. I personally love them and I can see FAR better than I could before with the combination of new housings and the conversion. Even in the dense fog in the coastal town I live in, I can see better. There are a LOT of wild animals around here including elk and deer, which frequent the highways, which are 120 kmh. Trust me, you need to see as clearly as possible out here. No street lamps on most roads just reflectors. I live in the boonies haha Edited January 18, 2015 by Nefarious 1 Link to comment Share on other sites More sharing options...
jamba Posted January 18, 2015 Share Posted January 18, 2015 Got chinese bag cover for sparewheel Lähetetty minun GT-S7710 laitteesta Tapatalkilla Link to comment Share on other sites More sharing options...
Soulust Posted January 18, 2015 Share Posted January 18, 2015 Started fab for my snorkel with a "Little" help Link to comment Share on other sites More sharing options...
SpecialWarr Posted January 18, 2015 Share Posted January 18, 2015 I finally had a nice "warm" day to install my daytime running light module from Canadian Tire. 90minutes and everything is tied down, wired and working like a charm. Monday will be soldering the connections and weather resistant heat shrink tubing. Notes for anyone else running an early wagon: R.h low beam is RED/BLACK wire; the L.h low is RED/GREEN! Link to comment Share on other sites More sharing options...
Nefarious Posted January 19, 2015 Share Posted January 19, 2015 Went out and cranked up a tiny bit and leveled out my two front torsion bars. One side was a bit higher than the other and it was driving me crazy... now I just need to set the camber and toe in the front end and aim my head lights. The new rig is really getting there now Link to comment Share on other sites More sharing options...
Harbinger Posted January 19, 2015 Share Posted January 19, 2015 (edited) Saturday I had the truck aligned. Yay for lifetime alignments at Firestone! Today I changed the oil/filter, spark plugs, wires, and the distributor cap and rotor. Put in NGK G Powers & some AC Delco 7mm wires, while the distributor parts were Bosch. I'm really glad I found a set of OEM spark plug tools @ the junk yard a few months back, they made the #6 cylinder into an easier job than I expected. Also wired up my new switch panel. Now the Hella 500's are relayed off of the high beams, and I have the wiring keyed off of the low beams for when I get my fog lights. Edited January 19, 2015 by Harbinger Link to comment Share on other sites More sharing options...
SpecialWarr Posted January 20, 2015 Share Posted January 20, 2015 Well. Apparently I am not as good an electrician as I thought. The path will not start now that I have installed the daytime running light module. I drove it to work, had interior lights and dash lights but not enough electricity to start the truck. A boost did nothing other than sparks at the negative of the battery. Cold,tired, and dark means I am going to be having words with Ernest tomorrow when I take the 2 buses, 2 subways and a taxi to get back to work a few hours late. Link to comment Share on other sites More sharing options...
toughroad Posted January 20, 2015 Share Posted January 20, 2015 Washed and applied wax into the paint and some dressing in the interior panels. Link to comment Share on other sites More sharing options...
