derrick719 Posted November 18, 2010 Share Posted November 18, 2010 hey so im freezing my butt off up here in the great white north as im getting very little heat from my pathfinders heater. did a frame swap so may have done something wrong refilling the coolent but not sure. the temp only goes to about 1/4 up the temp gauge at the most. is there something im not doing right never had heat probs with my z31s Link to comment Share on other sites More sharing options...
Nismojunky Posted November 19, 2010 Share Posted November 19, 2010 your heater hoses or core might be pluged pull them off and blow compressed air threw them Link to comment Share on other sites More sharing options...
onefast87 Posted November 19, 2010 Share Posted November 19, 2010 i have the same problem, i think its the thermostat. Link to comment Share on other sites More sharing options...
derrick719 Posted November 19, 2010 Author Share Posted November 19, 2010 ok bummer dont feel like pulling the engine apart in -15 + weather hoping it could of been a air pocket or something simple Link to comment Share on other sites More sharing options...
onefast87 Posted November 19, 2010 Share Posted November 19, 2010 ok bummer dont feel like pulling the engine apart in -15 + weather hoping it could of been a air pocket or something simple as a test remove the radiator cap and let the engine warm up, give it a couple revs. then shut off and re-install the cap, if there are air bubbles this should take care of it. Link to comment Share on other sites More sharing options...
Precise1 Posted November 19, 2010 Share Posted November 19, 2010 I think you need to move the truck to where it isn't asked to deal with such ridiculous conditions... Seriously though, how hot are the heater hoses?? Actual temp would be great, but can you hold them?? B Link to comment Share on other sites More sharing options...
GrimGreg Posted November 19, 2010 Share Posted November 19, 2010 It is probably the thermostat stuck open. Link to comment Share on other sites More sharing options...
derrick719 Posted November 19, 2010 Author Share Posted November 19, 2010 i havent checked as its only been a few days and i try to stay inside. tomorrow may be a little nicer. i thinking that but the gauge will go up then drop to the bottom after a while driving my z was stuck open just took along time to warm up. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 19, 2010 Share Posted November 19, 2010 maybe your coolant is low. When its low you get air in the tubes that circulate fromt the heater core to back to your radiator because these are the higest ones. Open air relief plug (found on rear drivers side of intake manifold) and Top off your coolant to 1/4" below the fill neck. Replace relief plug and Run your engine with the radiator cap off while looking thru the fill neck. Top off as needed so that you can always see fluid above the core. Wait for thermostat to open, you will know it is because the upper hose will heat up and you will see the fluid rushing by the neck. shut off engine,Top off your coolant to just below the overflow hose and pump the upper hose with your hand to relive air. Replace cap. Process can be repeated but it usually only takes once time unless the heater core has been replaced or emptied. I had the same problem and that is how I fixed yesterday. My wifes 94 had the same problem but it was because it was like 80% water so I re-filled it with 50/50. Now both my Pathfinders have nice hot air as soon as the needle starts to lift above the cold mark. Also, for cold climates you can run up to 75% coolant to help the engine retain more heat because "coolant" does not cool as well as water. Link to comment Share on other sites More sharing options...
adamzan Posted November 19, 2010 Share Posted November 19, 2010 If you get more heat while driving but less while idling and the gauge drops then it is most likely the thermostat. Link to comment Share on other sites More sharing options...
derrick719 Posted November 19, 2010 Author Share Posted November 19, 2010 the heats all over the place it drops to 0 when driving. ok i didnt know about the little bplug in the manifold so that could be one of my probs the manual didnt have any of that info Link to comment Share on other sites More sharing options...
Alkorahil Posted November 19, 2010 Share Posted November 19, 2010 I concour with the above: 1) check the coolant system for air pockets by 'burping' the system, air will catch in the heater core and the higher points of the system. 2) Check coolant level is correct. 3) Thermostat stuck open-replace the thermostat 4) faulty/clogged watercock to the heater core. 5) clogged heater core Please do all the above with the engine cold! Link to comment Share on other sites More sharing options...
derrick719 Posted November 20, 2010 Author Share Posted November 20, 2010 ya so i drove to calgary a hour and a half drive the engine its self is not getting hot. i can grab any part of the engine but the manifolds and not get burnt. the thermostat is freezing cold so im sure its that. wishing i had some spare cash to do that when the engine was out now. Link to comment Share on other sites More sharing options...
sewebster Posted November 20, 2010 Share Posted November 20, 2010 I think it's pretty easy to do the thermostat. drain radiator, remove fan and shroud, pull off lower hose, open thermostat housing? Maybe you need to remove the power steering belt? Link to comment Share on other sites More sharing options...
MY1PATH Posted November 20, 2010 Share Posted November 20, 2010 get a 180* thermostat it will help you in the cold and make sure your coolant is between 50/50 & 75/25 coolant/water. I have seen engines with the complete inabilty to warm up on a hot day because the owner put only water in it. Link to comment Share on other sites More sharing options...
adamzan Posted November 20, 2010 Share Posted November 20, 2010 From my experience a 170 was more than sufficient here in Ottawa ontario (The store only had that for a wd for some reason). But I don't live in Alberta so Idk what it's like there. Also just using the 50/50 mix is perfect for these trucks it seems. I have awesome heat in the winter and it never overheats in the summer. Make sure your fan clutch isn't staying on and not letting the truck warm up. Also you can block off part of the rad with a piece of cardboard and that will help it stay warmer. Link to comment Share on other sites More sharing options...
derrick719 Posted November 21, 2010 Author Share Posted November 21, 2010 ya i just dont want to go out in the dang cold and do it. the only having water in the rad and having trouble starting in the summer i dont belive as my z ran no prob with just water as the track did not allow cars with antifreeze race or have a extra catch can. ya ill be doing what the parts store recomends. im sure the clutch is fine as i can spin it by hand. Link to comment Share on other sites More sharing options...
adamzan Posted November 21, 2010 Share Posted November 21, 2010 when i did my tbelt i didn't do the tstat cause i thought waterpump and tbelt were all i needed and guess what that winter i had no heat and there i was doing the tstat in -20 weather. Link to comment Share on other sites More sharing options...
derrick719 Posted November 21, 2010 Author Share Posted November 21, 2010 ya lol i may b doing that but. i am looking to open my own little on the side shop or ill go bug my old boss to let me use the shop for a night Link to comment Share on other sites More sharing options...
GrimGreg Posted November 21, 2010 Share Posted November 21, 2010 Swivel head sockets make changing our thermostat almost as easy as a Chevy V8. Link to comment Share on other sites More sharing options...
sewebster Posted November 22, 2010 Share Posted November 22, 2010 maybe your coolant is low. When its low you get air in the tubes that circulate fromt the heater core to back to your radiator because these are the higest ones. Open air relief plug (found on rear drivers side of intake manifold) and Top off your coolant to 1/4" below the fill neck. Replace relief plug and Run your engine with the radiator cap off while looking thru the fill neck. Top off as needed so that you can always see fluid above the core. Wait for thermostat to open, you will know it is because the upper hose will heat up and you will see the fluid rushing by the neck. shut off engine,Top off your coolant to just below the overflow hose and pump the upper hose with your hand to relive air. Replace cap. Process can be repeated but it usually only takes once time unless the heater core has been replaced or emptied. I had the same problem and that is how I fixed yesterday. My wifes 94 had the same problem but it was because it was like 80% water so I re-filled it with 50/50. Now both my Pathfinders have nice hot air as soon as the needle starts to lift above the cold mark. Also, for cold climates you can run up to 75% coolant to help the engine retain more heat because "coolant" does not cool as well as water. I couldn't find this air relief plug... should my 91 have it? Link to comment Share on other sites More sharing options...
MY1PATH Posted November 22, 2010 Share Posted November 22, 2010 yes its a little 8or10mm head facing skyward on the upper manifold next to the Idle Air Control Valve. Some of them still have a silver sticker that says do not open when hot. Link to comment Share on other sites More sharing options...
sewebster Posted November 22, 2010 Share Posted November 22, 2010 Ah, ok, thanks, I was looking at the lower manifold. Yeah, I think I know where you are talking about now. I bet this is going to make filling the coolant way easier. Link to comment Share on other sites More sharing options...
94stickpathy Posted December 9, 2010 Share Posted December 9, 2010 Would this fix that fact that my pathy simply does not warm up? My heat inside the cabin is good but the needle barely gets a 1/4 of the way up. When it idles, it actually goes back down to C. Link to comment Share on other sites More sharing options...
MY1PATH Posted December 9, 2010 Share Posted December 9, 2010 mine does that too, I heven have half the radiator blocked with cardboard Link to comment Share on other sites More sharing options...
