PathyLE Posted March 8, 2010 Share Posted March 8, 2010 I've just installed the AC 2" coils. My issue is this: my shocks and struts are severely bottoming out. Like no travel whatsoever. I have the rancho rsx shocks and struts from AC installed. Am I doing something wrong here? Are there longer shocks and struts that I need, but am not seeing? Link to comment Share on other sites More sharing options...
dududuckling Posted March 8, 2010 Share Posted March 8, 2010 Bottoms out? And not topping out? I installed the AC lift last month. The front end will top out and not bottom out. The rear end does neither and is working fine even though I'm using Pro Comp that is about two inches shorter than the RS9000XL. Link to comment Share on other sites More sharing options...
PathyLE Posted March 8, 2010 Author Share Posted March 8, 2010 Yes, topping, not bottoming. I'm thinking of switching to the bilstein shocks. AC has a set for the 2" lift. Link to comment Share on other sites More sharing options...
dududuckling Posted March 8, 2010 Share Posted March 8, 2010 For the front end, I go with the KYB struts and there's not much you can do about topping out. I haven't come across longer travelling struts, but I might be mistaken. As for the shocks, I've heard great stuff about Bilstein. Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted March 14, 2010 Share Posted March 14, 2010 If I'm not mistaken 17503 is your part number...... Link to comment Share on other sites More sharing options...
180sx Posted March 14, 2010 Share Posted March 14, 2010 There are no longer struts. You'll just have to get used to the topping out or get straps to prevent it (Like nissandoms47). KYB GR-2's are the most recommended struts. As for the rear, you should be fine for a while. Jose Link to comment Share on other sites More sharing options...
laxman0324 Posted March 15, 2010 Share Posted March 15, 2010 Struts that extend longer would be pointless because they would put the CV's at a severe angle...What I hear from most people is the topping out goes away after a while...I was ripped off and sold blown KYB's with the lift springs so mine never made a noise when topping out... Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 18, 2010 Share Posted March 18, 2010 Topping out struts with lift coils is pretty much inevitable... It does go away over time as the coils settle. Link to comment Share on other sites More sharing options...
