87Elephant Posted November 11, 2009 Share Posted November 11, 2009 I have a ingition problem with the 89 , it doesnt have a key to start so i bought it without a key , but it has a switch thatll start it with anything flat.. screw driver..other keys.. sometimes dimes.. Ghetto i kno is there any possible chance i can switch the ingition from the 87 and install it in the 89. ? would it work? Link to comment Share on other sites More sharing options...
Precise1 Posted November 11, 2009 Share Posted November 11, 2009 As long as the 89 is a TBI injected 2 door, I'm betting there would be no issue?? One good double check is to go to a parts site (like rockauto or courtesyparts or something) and look up the parts you want to exchange to see if there are different listings/part numbers for the different years. It's not a perfect check, but a good place to start. B BTW, isn't that Steeevo's truck?? (ruggedrocks.com) Link to comment Share on other sites More sharing options...
87Elephant Posted November 11, 2009 Author Share Posted November 11, 2009 As long as the 89 is a TBI injected 2 door, I'm betting there would be no issue?? One good double check is to go to a parts site (like rockauto or courtesyparts or something) and look up the parts you want to exchange to see if there are different listings/part numbers for the different years. It's not a perfect check, but a good place to start. B BTW, isn't that Steeevo's truck?? (ruggedrocks.com) Ok thanks i hope itll work , oo idk i just snagged a pic off the internet real quick.. was in ahurry had to got o the dentist.. Link to comment Share on other sites More sharing options...
GrimGreg Posted November 11, 2009 Share Posted November 11, 2009 The switch part should interchange with any year, I have the electrical end off of a 94 in my 88, and it was the exact same as the original 88 one, same connector even, which was the biggest shock. Link to comment Share on other sites More sharing options...
87Elephant Posted November 12, 2009 Author Share Posted November 12, 2009 The switch part should interchange with any year, I have the electrical end off of a 94 in my 88, and it was the exact same as the original 88 one, same connector even, which was the biggest shock. okay , so its with what your saying its just plug n play? okay thats good to know cause i really wanna be able to drive it around and park it without the chance of it getting stolen Link to comment Share on other sites More sharing options...
GrimGreg Posted November 12, 2009 Share Posted November 12, 2009 okay , so its with what your saying its just plug n play? okay thats good to know cause i really wanna be able to drive it around and park it without the chance of it getting stolen Yes, however the keyed part is held in with security bolts (for obvious reasons) that usually need drilled out to remove. Link to comment Share on other sites More sharing options...
