backing out of a parking space and i feel
ac92pathfinder
As we just discussed on AIM since you have a LSD rear (had him check by lifting up the back and spinning a tire, other tire spun the same direction) it's probably from the LSD engaging and disengaging due to the tight turn and relatively high amount of torque being applied by the engine in that situation.
Or at least I hope that's what it is, as my Pathy does that too when backing out of some parking spots.
Also mod's could this get moved to General Discussion or The Garage?
Edited by SC88Pathy
a off and on vibration and i also hear woo woo woo sounds like a bad wheel bearing. does it too when i pull in only does it when the wheel is cranked either way when the car is moving. thanks
yup i agree lsd
