ticker Posted May 12, 2009 Share Posted May 12, 2009 (edited) My CEL came on yesterday. I had the guys at Auto Zone pull the codes which are below. I used the search and got these definitions but I'm not really sure what they mean or how to begin to address the probem. Advice, hints, magic spells?? Also is it cool to drive it as is? seems to be running ok Thanks P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring P0325 Knock Sensor, Bank 1 edited title to better reflect topic -T Edited August 10, 2009 by ticker Link to comment Share on other sites More sharing options...
Alkorahil Posted May 12, 2009 Share Posted May 12, 2009 My CEL came on yesterday. I had the guys at Auto Zone pull the codes which are below. I used the search and got these definitions but I'm not really sure what they mean or how to begin to address the probem. Advice, hints, magic spells?? Also is it cool to drive it as is? seems to be running ok Thanks P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring P0325 Knock Sensor, Bank 1 Code P0325 is the knock sensor which is a pain to get to. I would suspect that it may be causing the other two codes to come up. (P0151 and P0131) You have one of two things going on witht he knock sensor, either there is a bad/corroded wire or plug at the sensor, or the knock sensor is bad and needs to be replaced. Link to comment Share on other sites More sharing options...
fleurys Posted May 12, 2009 Share Posted May 12, 2009 here you go.. http://www.4shared.com/file/104999412/90da...procedures.html This is the complete mitchell diagnostic portion for your 98 pathfinder. You will find all the codes and the procedures to diagnose them. Let us know how this thing end ! Cheers. S. Link to comment Share on other sites More sharing options...
ticker Posted May 13, 2009 Author Share Posted May 13, 2009 here you go.. http://www.4shared.com/file/104999412/90da...procedures.html This is the complete mitchell diagnostic portion for your 98 pathfinder. You will find all the codes and the procedures to diagnose them. Let us know how this thing end ! Cheers. S. sweet thanks to both of you, I'll let you know what I find out. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 14, 2009 Share Posted May 14, 2009 There is a TSB concerning some of these codes. NTB99-004b. Says it may be a poor ground connection. A new ground sub harness is recommended to be installed. Sub harness- 24075-0W060 Wiring clip- 01552-00401KK Hex Bolt- 08146-8121G Link to comment Share on other sites More sharing options...
ticker Posted July 19, 2009 Author Share Posted July 19, 2009 There is a TSB concerning some of these codes. NTB99-004b. Says it may be a poor ground connection. A new ground sub harness is recommended to be installed. Sub harness- 24075-0W060 Wiring clip- 01552-00401KK Hex Bolt- 08146-8121G So I added a new harness and it seems to be working. I don't know if this deserves a sticky or not but It's an easy and cheap fix for this problem. Thanks here's the how to: nissan_o2_sensor_dtc_repairs.pdf 1 Link to comment Share on other sites More sharing options...
Precise1 Posted July 20, 2009 Share Posted July 20, 2009 It seems pretty valuable to me. I'll pin it now and people can fight about it later... B Link to comment Share on other sites More sharing options...
dkpath96 Posted September 25, 2009 Share Posted September 25, 2009 ticker, where did you buy the harness? Link to comment Share on other sites More sharing options...
ticker Posted September 26, 2009 Author Share Posted September 26, 2009 ticker, where did you buy the harness? I made the harness from spare wire and some wire connectors and bolts from the auto parts store. $10 vs $90+ from the dealer. Its raining like a mofo today. I'll take some pics tomorrow. Link to comment Share on other sites More sharing options...
carwilef7 Posted September 27, 2009 Share Posted September 27, 2009 I had some of those codes at one time, but they seem to have stopped once I fixed the flooding problem (coolant temp sensor - never got a code for it though) seafoamed it, and ran it hot -+3000rpm - occasionally by going 65mph w/ the O/D off. That burned off the goo. Good info to have though - if it comes back. THANKS! Link to comment Share on other sites More sharing options...
skulptr Posted February 2, 2010 Share Posted February 2, 2010 So I added a new harness and it seems to be working. I don't know if this deserves a sticky or not but It's an easy and cheap fix for this problem. Thanks here's the how to: if someone has the file still can it be reposted? i have no idea what harness and where is being talked about, but i'm constantly getting the knock sensor and o2 codes. Link to comment Share on other sites More sharing options...
Sick98Path Posted February 8, 2010 Share Posted February 8, 2010 if someone has the file still can it be reposted? i have no idea what harness and where is being talked about, but i'm constantly getting the knock sensor and o2 codes. Me too I need to fix this im getting around 11mpg Link to comment Share on other sites More sharing options...
skulptr Posted February 8, 2010 Share Posted February 8, 2010 Me too I need to fix this im getting around 11mpg sounds like you have more going on than just a faulty code trip. whens the last time you did a full tune up? Link to comment Share on other sites More sharing options...
Sick98Path Posted February 8, 2010 Share Posted February 8, 2010 sounds like you have more going on than just a faulty code trip. whens the last time you did a full tune up? Whats sad is I already put new wires, plugs and a fuel filter and it didnt change the mileage one bit. cleared the codes and took of battery terminal for 12 hours didnt fix or help it at all. So I bought a new OEM knock sensor was thinking about taking it all apart and trying that to see if it would fix it. I read on a couple other forums that theres a way to install knock sensor on the top of intake manifold to by pass taking off the intake manifold anyone done that befor? heres a link Knock sensor relocation Thanks in advance Link to comment Share on other sites More sharing options...
Sick98Path Posted February 11, 2010 Share Posted February 11, 2010 So no one had had bad gas milage that was caused by there knock sensor going bad? Link to comment Share on other sites More sharing options...
skulptr Posted March 14, 2010 Share Posted March 14, 2010 So no one had had bad gas milage that was caused by there knock sensor going bad? my mileage has not changed. infact my egr has gone bad, and my gas mileage got better Link to comment Share on other sites More sharing options...
maikan Posted April 7, 2010 Share Posted April 7, 2010 I can't have access to the PDF How-To. Is this a problem with my computer or this document is lost in the immensity of the web. Have these code (knock sensor, O2) and I want to get rid of these. Link to comment Share on other sites More sharing options...
Kingman Posted April 8, 2010 Share Posted April 8, 2010 my mileage has not changed. infact my egr has gone bad, and my gas mileage got better It should improve, cool straight air going into the engine rather than being mixed with very hot, re-used exhaust gasses. Emission systems are the biggest gas and power sucking systems on engines. Link to comment Share on other sites More sharing options...
MJBBMANO Posted April 15, 2010 Share Posted April 15, 2010 here you go.. http://www.4shared.com/file/104999412/90da...procedures.html This is the complete mitchell diagnostic portion for your 98 pathfinder. You will find all the codes and the procedures to diagnose them. Let us know how this thing end ! Cheers. S. Hello, Do you have one or know where I can get the pathfinder 1997 LE diagnostic procedures? Thanks, Link to comment Share on other sites More sharing options...
Sick98Path Posted April 26, 2010 Share Posted April 26, 2010 sounds like you have more going on than just a faulty code trip. whens the last time you did a full tune up? I had the intake manifold off traced the harness up too the top main harness. Then I cleaned the intake track changed plugs again installed new gaskets and water hoses with new clamps. I reset my ecu happy to say I am getting between 15-16mpg and no more codes I think mounting this on top of intake manifold was a great.I love being able to change it in future if it goes again with out pulling the intake manifold off which sucked to do. The only draw back I see is the fact that it wont detect a rod knock or dentination as quick... My truck now starts and runs way better then it has in a long time After about 4500 miles Link to comment Share on other sites More sharing options...
laxman0324 Posted April 29, 2010 Share Posted April 29, 2010 It should improve, cool straight air going into the engine rather than being mixed with very hot, re-used exhaust gasses. Emission systems are the biggest gas and power sucking systems on engines. a little off topic but this is why hybrids of today can't even match the Honda CR-X's mileage from 20 years ago... Link to comment Share on other sites More sharing options...
Towncivilian Posted March 17, 2012 Share Posted March 17, 2012 Looks like the attachment died, here's a working link: NTB99-004b - 1996-00 PATHFINDER, 1999-2004 FRONTIER (V-6) AND 2000-2004 XTERRA (V-6); MIL 'ON' WITH O2 SENSOR DTCs Link to comment Share on other sites More sharing options...
Rebelord Posted March 18, 2013 Share Posted March 18, 2013 anyone have a good link to the full TSB with diagrams and such? I made a harness but would like to make sure I have it correct. Link to comment Share on other sites More sharing options...
Towncivilian Posted March 22, 2013 Share Posted March 22, 2013 https://docs.google.com/file/d/0B5mpmm482r0VcWhqRTdqNG5jTk0/edit?usp=sharing 1 Link to comment Share on other sites More sharing options...
Rebelord Posted March 23, 2013 Share Posted March 23, 2013 Yep, I have it right. But still Bank 2 Sensor 2 High voltage. Second new sensor too. This is aggravating. Link to comment Share on other sites More sharing options...
