nmpath Posted May 7, 2009 Share Posted May 7, 2009 Im in the process of replacing the rear brakes on my 2002, and I dont know exactly how to adjust the rear shoes/pads. Im used to just turning the star gear until the pads barely touch the drum. The nissan service manual doesnt say anything about this, but it says to adjust the parking brake cable. Do I need to do both? Thanks Link to comment Share on other sites More sharing options...
shift220 Posted May 7, 2009 Share Posted May 7, 2009 Im in the process of replacing the rear brakes on my 2002, and I dont know exactly how to adjust the rear shoes/pads. Im used to just turning the star gear until the pads barely touch the drum. The nissan service manual doesnt say anything about this, but it says to adjust the parking brake cable. Do I need to do both? Thanks I would do just like you said and adjust until they are snug. The parking brake should not need to be adjusted after that. Usually drum brakes are self-adjusting in where they tighten up when you brake hard in reverse but i'm not 100% sure on these trucks. Link to comment Share on other sites More sharing options...
