filthyphil Posted April 9, 2009 Share Posted April 9, 2009 Well im having a bit of trouble with my injection pump Went out to the old girl this arvo and there was a small diesel stane on my driveway, so i started her up and sure enough diesel was dripping from the injection pump Just what i need!!!!!!!!!!!!! Any help would be appreciated!!!!!! Link to comment Share on other sites More sharing options...
sw Posted April 15, 2009 Share Posted April 15, 2009 Any help would be appreciated!!!!!! a boss at a previous work place had the same thing. ran fine just developed a leak him & his brother pulled the pump out and put some new seals it, seemed to stop the leak. i left that work place shortly after, so i dont know if it was a permanent fix or not how handy are you? Link to comment Share on other sites More sharing options...
filthyphil Posted April 15, 2009 Author Share Posted April 15, 2009 a boss at a previous work place had the same thing. ran fine just developed a leak him & his brother pulled the pump out and put some new seals it, seemed to stop the leak. i left that work place shortly after, so i dont know if it was a permanent fix or not how handy are you? Cheers sw, The shop quoted $600 nz to replace seals in the pump and replace the injectors get it running sweet!!! Otherwise have a go myself/with help!!!! The only way to realy no your pathy is to dive in and have a go!!!!!!!!!!! And i have the TD27 service manual if i get lost!!!! Link to comment Share on other sites More sharing options...
