Crispyc Posted March 15, 2009 Share Posted March 15, 2009 Every time it rains the carpet in my Pathfinders cargo area gets wet. I believe rain is leaking in from the rear hatch window weather strip. The weatherstrip does not appear to be torn or dry rotted. I was just wondering if anyone else has had this problem and fixed it. Link to comment Share on other sites More sharing options...
GrimGreg Posted March 15, 2009 Share Posted March 15, 2009 Try adjusting the latch, it might not be pulling the window tight enough to seal out the water. Link to comment Share on other sites More sharing options...
Crispyc Posted March 16, 2009 Author Share Posted March 16, 2009 How do I adjust it? Link to comment Share on other sites More sharing options...
Channel595 Posted March 16, 2009 Share Posted March 16, 2009 mine did when i first got it it leaked through the screw holes on the hinges, i unscrewed the rear window from the hinges and used gasket sealer on the rubber piece, hasnt leaked since. honda bond is the @!*%. Link to comment Share on other sites More sharing options...
nismothunder Posted March 18, 2009 Share Posted March 18, 2009 (edited) Sillicon the treads of the screws.When I got mine I had to replace one of them. Get the black RTV its the water proof kind so it doesnt wether as fast. Edited March 18, 2009 by nismothunder Link to comment Share on other sites More sharing options...
94extreme Posted March 18, 2009 Share Posted March 18, 2009 check the whole gate too. that's more likely to be leaking as there is area for the water to be held up in there. Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 18, 2009 Share Posted March 18, 2009 mine did when i first got it it leaked through the screw holes on the hinges, i unscrewed the rear window from the hinges and used gasket sealer on the rubber piece, hasnt leaked since. honda bond is the @!*%. my 87 did that too Link to comment Share on other sites More sharing options...
5523Pathfinder Posted March 18, 2009 Share Posted March 18, 2009 Mine was leaking at the top of the rear window weatherstrip. I could see streaks down the glass everytime I washed it. I took some small vacuum hose and made a small slit in the weatherstrip. I sprayed silicone lube in the slit and on the piece of vaccum hose. Slid the hose into the slit and down the weatherstrip. Sealed the end with some weatherstrip adhesive and let dry. Its been fine ever since. Link to comment Share on other sites More sharing options...
Tosh Posted April 15, 2009 Share Posted April 15, 2009 mine does that too it leaks from the screws. i haven't got to fixin it yet though Link to comment Share on other sites More sharing options...
morpheus Posted April 15, 2009 Share Posted April 15, 2009 To find a water leak, climb in the back and close everything up. Have a friend use a garden hose (not a pressure washer) and hose down the suspected areas. Run the water for several minutes in each location and watch for it coming in. Link to comment Share on other sites More sharing options...
PamPoovey Posted August 14, 2017 Share Posted August 14, 2017 I know my weatherstrip needs to replaced -I used to haul all sorts, beating up the weather strip. The Nissan part # is 90310-41G16 but I sure don't like the price! http://www.nissanpartswebstore.com/p/Nissan__/Glass-wstrip/54400721/9031041G16.html Anyone know if I can get away with using from another Pathy year (I also have an 02) http://www.ebay.com/itm/NISSAN-OEM-05-12-Pathfinder-Lift-Gate-Weatherstrip-Seal-90310EA50A/201907752205?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D44732%26meid%3D9d6c21afeb9b4bb7b8dd11abc86ecca3%26pid%3D100623%26rk%3D1%26rkt%3D3%26sd%3D322545043553 or if you think this may work: http://www.ebay.com/itm/20ft-05-Rubber-Door-Edge-Seal-Trim-Strip-All-Weather-Protect-For-Chevy-Camaro/132066306464?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 If money wasn't an issue, I'd go with the Nissan straight up! As they say on Game of Thrones, winter is coming! I want to resolve this leak real soon. Link to comment Share on other sites More sharing options...
Citron Posted August 14, 2017 Share Posted August 14, 2017 I used a universal bulb seal from J.C. Whitney to replace the seal around my rear glass. Just need to make sure all of the measurements are correct. You do need the one around the glass and not the one around the door right? Link to comment Share on other sites More sharing options...
PamPoovey Posted August 14, 2017 Share Posted August 14, 2017 Dang, thought it had registered my response earlier. Yes, the one that rest under the glass of the lift gate. Link to comment Share on other sites More sharing options...
PamPoovey Posted August 22, 2017 Share Posted August 22, 2017 This was the one that I ended up purchasing https://smile.amazon.com/gp/product/B00NLQ1T6O/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 (the price has increased since I purchased) And now I am waiting for the next rain to see if it works as great as it looks! It definitely was the seal, it was quite wet in on corner once I lifted off the old weather strip. Link to comment Share on other sites More sharing options...
Citron Posted August 23, 2017 Share Posted August 23, 2017 I hope it works out. I wish I had seen that because the one I bought only came in 25' chunks, so I have a lot left over. Link to comment Share on other sites More sharing options...
PamPoovey Posted August 23, 2017 Share Posted August 23, 2017 I bought the 25' one because my luck, 10' wouldn't be enough due to the facotry's way of trimming it or mine. Now I am afraid to measure what's left! 1 Link to comment Share on other sites More sharing options...
