Channel595 Posted February 9, 2009 Share Posted February 9, 2009 so i know my low gas light doesent work and i see no check engine light on during bulb check... did some just not have any light? Link to comment Share on other sites More sharing options...
94extreme Posted February 9, 2009 Share Posted February 9, 2009 it has the CEL light. they all do. Link to comment Share on other sites More sharing options...
edicer2 Posted February 9, 2009 Share Posted February 9, 2009 my gas light doesnt come on either Link to comment Share on other sites More sharing options...
silver97ex Posted February 9, 2009 Share Posted February 9, 2009 My check engine light comes on when I get really low on gas Link to comment Share on other sites More sharing options...
Precise1 Posted February 10, 2009 Share Posted February 10, 2009 Pull the instrument cluster, check the connectors, tighten the brass screws (ground) and replace the bulbs... B Link to comment Share on other sites More sharing options...
Channel595 Posted February 10, 2009 Author Share Posted February 10, 2009 where is it in the gauge cluster? Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 10, 2009 Share Posted February 10, 2009 pull the cluster and pull 1 bulb at a time and shine a flashlight behind it...you'll find it eventually...if you have a bright enough light you can shine it on the front face and be able to see it...i'm not sure exactly where it is but you should be able to find it Link to comment Share on other sites More sharing options...
Channel595 Posted February 15, 2009 Author Share Posted February 15, 2009 pull the cluster and pull 1 bulb at a time and shine a flashlight behind it...you'll find it eventually...if you have a bright enough light you can shine it on the front face and be able to see it...i'm not sure exactly where it is but you should be able to find it if you had one it should come on with key on and then go off, and im pretty sure you would know where that is... and im pretty sure that some pathfinders just dont have it Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 15, 2009 Share Posted February 15, 2009 I've seen some people say they have no CEL on the non-CA emissions-equipped WD21's. No idea why. Link to comment Share on other sites More sharing options...
Indigent Posted February 15, 2009 Share Posted February 15, 2009 Of my three pathies, the only one that has a CEL is my 95. My 91 and my 90 do not. Link to comment Share on other sites More sharing options...
