found springs...
Channel595
i've got some Jim Conner Racing springs that are red...not sure you can designate what they are just by the color though...if its a you pull it maybe pull them and then compare it to a stock spring (diameter of coil and height of spring)not sure how to tell you to check to see how much lift it provides but it would let you know a lil more about the springs
