icemonkey Posted February 5, 2009 Share Posted February 5, 2009 Just a quick question. Are all timing belt kits for VG30E engines the same? I found a great price on Maxima V6 VG30E kit ($120) comes with timing belt water pump timing belt tensioner front crankshaft seal 2 front camshaft seals and 3 accessory drive belts, will this fit my Pathfinder? Any suggestions for Many many thanks. Avery Link to comment Share on other sites More sharing options...
Kingman Posted February 5, 2009 Share Posted February 5, 2009 (edited) It will as long as its the SOHC engine, I think. I'm assuming its the SOHC engine because that's what the alternators that fit our Pathys come off of. Or I'm just retarded and getting things mixed up in the head, which happens quite a bit actually. Edited February 5, 2009 by kingman92010 Link to comment Share on other sites More sharing options...
icemonkey Posted February 5, 2009 Author Share Posted February 5, 2009 Thanks, I might just risk it... Cheers Link to comment Share on other sites More sharing options...
jgt Posted February 5, 2009 Share Posted February 5, 2009 if i remember correctly, the 2wd and 4wd water pump has a slightly different configuration. I don't have the manual with me or else I'd post a picture. Link to comment Share on other sites More sharing options...
icemonkey Posted February 5, 2009 Author Share Posted February 5, 2009 Hmmmm... Link to comment Share on other sites More sharing options...
burton8it Posted February 5, 2009 Share Posted February 5, 2009 Just a quick question. Are all timing belt kits for VG30E engines the same? I found a great price on Maxima V6 VG30E kit ($120) comes with timing belt water pump timing belt tensioner front crankshaft seal 2 front camshaft seals and 3 accessory drive belts, will this fit my Pathfinder? Any suggestions for Many many thanks. Avery I use this site all the time for looking up parts makes it super easy specially cause there are pictures lol http://www.rockauto.com Link to comment Share on other sites More sharing options...
Indigent Posted February 5, 2009 Share Posted February 5, 2009 I seriously doubt it. It is possible, but even the 90-93 pathy belts are different from the 94-95 ones. You never really know when Nissan did what with different models. For example, the 300zx had a VG30E in the 80's when the Pathy had the VG30I. The best way to check would be to compare the Nissan part numbers for each part on each vehicle seperately in something like FAST. Link to comment Share on other sites More sharing options...
GrimGreg Posted February 5, 2009 Share Posted February 5, 2009 if i remember correctly, the 2wd and 4wd water pump has a slightly different configuration. I don't have the manual with me or else I'd post a picture. Correct, our pump housing makes up part of the timing cover, 2wds the pump housing is smaller and only covers the pump and flow chennels. The 2wd pump "can" be used with no coolent flow or leak issues, but your timing belt will have about 2 inches at either side just flapping in the wind. Also, the drive belts in that kit are probably the wrong size for the accessories. Link to comment Share on other sites More sharing options...
icemonkey Posted February 5, 2009 Author Share Posted February 5, 2009 Ok is there someone that I should go to? I will check out RockAuto, but if there is someone out there who would have another option? Does the site have any sponsors? or is there someone here who works for a great parts company? Thanks again Link to comment Share on other sites More sharing options...
Indigent Posted February 7, 2009 Share Posted February 7, 2009 Ok is there someone that I should go to? I will check out RockAuto, but if there is someone out there who would have another option? Does the site have any sponsors? or is there someone here who works for a great parts company? Thanks again Other than the sites listed on here like www.courtesyparts.com and rock auto, have you tried dealing locally? There is a great shop in my town called Triangle Auto that has never let me down. You might be surprised if you get outside of those big chain parts stores and check the little guy down the street. YMMV Link to comment Share on other sites More sharing options...
Channel595 Posted February 16, 2009 Share Posted February 16, 2009 there is 2 different kinds dont know they year split but there is square tooth(early) and round tooth (later) and as for the 100k belt its the same exact part as the 60k belt Link to comment Share on other sites More sharing options...
Pinip Posted April 12, 2009 Share Posted April 12, 2009 (edited) there is 2 different kinds dont know they year split but there is square tooth(early) and round tooth (later) and as for the 100k belt its the same exact part as the 60k belt Nissan changed the tooth design for timing belts on VG30E engines from one with 133 square teeth to one with 133 round teeth. The change occurred during the 7/93 production month... although i have seen advertisement for modeles up to 1994 !?! Would that mean that prior to 7/1993 , belt is good for only 96000 km or 60000 miles (square teeth) and after 7/1993 the belt (round teeth) good for 160000 km or 100000 miles ? ...mine was changed 86000km or 53750 miles ago ... i imagine they have installed square teeth ...Have they ? or could they just have installed a round teeth one... would that be possible or not ? ... i am grinding my own 32 teeth now just trying to figure it out... since i drove 86000 km or 53750 miles since !! Edited April 12, 2009 by Pinip Link to comment Share on other sites More sharing options...
Slick Posted April 12, 2009 Share Posted April 12, 2009 (edited) i paid $85 from parts dinosaur in AZ. full kit, fast shipping..... have actually ordered 2 of them........ great peeps to deal with Edited April 12, 2009 by Slick Link to comment Share on other sites More sharing options...
