vanuatoo Posted January 6, 2009 Share Posted January 6, 2009 Hello I've got 2003 SE. I've looked into the maintenance schedule and it says that I should change Microcabin filter in every 12 months and also there is a asterisk saying that that feature might be optional. How should I check if my car has that filter and where it's located? Link to comment Share on other sites More sharing options...
inanima Posted January 6, 2009 Share Posted January 6, 2009 It's behind the glovebox. here's one link: http://www.yournissanparts.com/catalog.asp...75&detail=1 It's easy to get too, just be careful pulling it out. Link to comment Share on other sites More sharing options...
Trainman Posted January 6, 2009 Share Posted January 6, 2009 Lots of info here: In Cabin Air Filter Installation Instructions Link to comment Share on other sites More sharing options...
vanuatoo Posted January 7, 2009 Author Share Posted January 7, 2009 Instructions say that one should remove negative battery cable. Why is it necessary? Also on this image I clearly see where 4 screws are located but the image is unclear when pointing to the middle up 2 screws. My guess is that 2 middle up screws are located side by side on the same line as the outer ones. So we've got 4 on the top and 2 on the bottom. Is that right? Link to comment Share on other sites More sharing options...
BowTied Posted January 7, 2009 Share Posted January 7, 2009 battery cable - due to the airbag module being right there? Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted January 7, 2009 Share Posted January 7, 2009 Just a safety measure to disable the airbag while you're replacing the filter...? Link to comment Share on other sites More sharing options...
vanuatoo Posted August 1, 2009 Author Share Posted August 1, 2009 Is there any other way to find out if I have in-cabin air filter without removing the glove box? Link to comment Share on other sites More sharing options...
inanima Posted August 2, 2009 Share Posted August 2, 2009 Is there any other way to find out if I have in-cabin air filter without removing the glove box? Just assume you do. It only takes like 10 minutes max to take the glovebox out. Been 8 months? Link to comment Share on other sites More sharing options...
PathA4 Posted August 19, 2009 Share Posted August 19, 2009 when I opened up my wife's 04 SE, it wasn't obvious where the filters would go. then I saw the instructions that suggest cutting open the cooler unit. that's where I stopped and put everything back together. has anybody actually done this modification? the instructions are pretty vague and refer only to cutting out the shaded area. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted August 19, 2009 Share Posted August 19, 2009 Ive installed a few of them. Its not hard, and when you drop the glovebox out of the way, you can see where you need to cut. Just have a nice and sharp Exacto knife on hand. Be careful!!! Link to comment Share on other sites More sharing options...
ennacac Posted August 20, 2009 Share Posted August 20, 2009 Didn't have to do any cutting on my Altima, just take off a cover and pull the filter out. Mine looked like it had never been changed from when the car was new and boy was it dirty! Tom Ive installed a few of them. Its not hard, and when you drop the glovebox out of the way, you can see where you need to cut. Just have a nice and sharp Exacto knife on hand. Be careful!!! Link to comment Share on other sites More sharing options...
5523Pathfinder Posted August 20, 2009 Share Posted August 20, 2009 Some came with them, other didnt. There is details on how to install it, in the accessorie catolog. Link to comment Share on other sites More sharing options...
