wisco4x2 Posted August 2, 2019 Share Posted August 2, 2019 can someone answer me if could a 275/55r20 tire with a 2.5" lift the rim are 20x9 0 offset. will they fit and won't rub ? the tire size in inches is 31.90x 10.50 Link to comment Share on other sites More sharing options...
benconditt1810 Posted December 15, 2019 Share Posted December 15, 2019 I’m about to put on some cragar 397, 15/8 with +6 offset. The tires are 15 inch 31/ 10.50 aggressive mud tires. My pathfinder is a 96, 4 by 4 with all stock suspension. Will this setup work Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 15, 2019 Share Posted December 15, 2019 2 hours ago, benconditt1810 said: I’m about to put on some cragar 397, 15/8 with +6 offset. The tires are 15 inch 31/ 10.50 aggressive mud tires. My pathfinder is a 96, 4 by 4 with all stock suspension. Will this setup work Should work. Looks like those wheels have 4.75" of backspacing, so if you want to go with a larger tire in the future it won't work, but for a 31x10.5 you'll be good. Link to comment Share on other sites More sharing options...
benconditt1810 Posted December 16, 2019 Share Posted December 16, 2019 On 12/15/2019 at 1:15 AM, mjotrainbrain said: Should work. Looks like those wheels have 4.75" of backspacing, so if you want to go with a larger tire in the future it won't work, but for a 31x10.5 you'll be good. Thanks I’ll post info and picks when I get them on Link to comment Share on other sites More sharing options...
Cbiggy Posted April 5, 2020 Share Posted April 5, 2020 Would a 265/75r16 clear the strut perch on a 16x8 with 4" backspace? Link to comment Share on other sites More sharing options...
Eric53 Posted June 12, 2020 Share Posted June 12, 2020 I have an 01 Pathfinder LE stock as stock can be. I am going to be installing 2 inch spring and strut spacers and want to put 265/75/16 tires on my stock 6 spoke wheels. Does anyone know if and how much of a wheel spacer i would need to fit those tires? Pic is of my Pathy Link to comment Share on other sites More sharing options...
v6tx Posted July 2, 2020 Share Posted July 2, 2020 (edited) Good thread. I am shopping for wheels and tires now. Here's my thought process on it. LIFT & SUSPENSION: Would like to do this later in one go (KYB, Rancho / SFCreations vs AC etc.) WHEELS & TIRES: Want to do this first to take advantage of some July 4th deals. OEM: 17" 3-spoke Infiniti Wheel with 245/65/17 sizing. Backspacing Unknown. GOAL: Light to medium offroad/low mud capability for now with wider contact patch and more sidewall for daily driving. TIRES: Set on the COOPER Discoverer AT3 4S after seeing a great Youtube Review on them WHEELS: Will be 15"x8" with 3.75" backspacing In the interest of trying to keep the same dimensions, the most equal size alternative will be a 265/70/15 tire. I believe a 265/75/15 would be just enough to rub or hit the perch with normal PSI running and I don't want to run deflated tires (unless in mud) at higher speeds. Based on Tire Size Comparison Calculator at https://tiresize.com/comparison/ this will be the most equal match: Edited July 2, 2020 by v6tx 1 Link to comment Share on other sites More sharing options...
nated0g Posted August 19, 2020 Share Posted August 19, 2020 On 4/5/2020 at 4:29 PM, Cbiggy said: Would a 265/75r16 clear the strut perch on a 16x8 with 4" backspace? Yes, I just installed this and can confirm. I have a 2" lift and had to do a bit of trimming. Link to comment Share on other sites More sharing options...
Eric53 Posted September 14, 2020 Share Posted September 14, 2020 (edited) 2001 Pathfinder LE SFCreation 2” all around lift spring and strut spacers stock 2000 pathfinder wheels no spacers 235/85/16 thunderer trac grip (31.7”) Edited September 14, 2020 by Eric53 Added photo Link to comment Share on other sites More sharing options...
dezm Posted November 12, 2020 Share Posted November 12, 2020 On 9/14/2020 at 12:00 PM, Eric53 said: 2001 Pathfinder LE SFCreation 2” all around lift spring and strut spacers stock 2000 pathfinder wheels no spacers 235/85/16 thunderer trac grip (31.7”) Whaaat your 235/85/16 fit with no wheel spacers? Everyone I've seen with them said they needed at least an inch on their front wheels Link to comment Share on other sites More sharing options...
ioeharci Posted March 22, 2021 Share Posted March 22, 2021 Gents, Please consider this setup for a blacked out 04 R50? Wheels: Black Rhino "Arsenal" model number: 2095ARS-86140M12: 20x9.5 Tires: 245/60R20 or 235/55R20 What is the factory wheel offset on the 2004 SE 4WD w/o TPMS? Link to comment Share on other sites More sharing options...
surf1980 Posted May 9, 2021 Share Posted May 9, 2021 Year: 1997 LE 4wdlift : no liftWheels : 15" stock Le wheelsTires : 31x10.5x15 BFG K02Notes: searched the forum to see if I could mount 31s on stock Le rims. Mixed feedback so I thought it was worth a shot and got the local shop give it a try. Slight rub at full lock but worksSent from my moto g(7) play using Tapatalk Link to comment Share on other sites More sharing options...
Robertiko_138 Posted July 25, 2022 Share Posted July 25, 2022 (edited) Year: 2003 Front Lift : 2in AC Springs, KYB Extended Struts Rear Lift: NRC9449 Springs (2.5in lift approx), Bilstein 5100 extended shocks Wheels : U.S. Wheel Series 304, 15x8, -19 offset, 3.75 backspace Tires : Falken Wildpeak AT3, 31x10.5 Notes: Both Front tires will rub the mudflap behind the tire in the front wheel well when making sharp turns or at full lock. Easy solution is to remove that mudflap, but I'm just letting the tires wear it down. Plus it's kind of fun to see people react to the noise when I'm parking. Alignment wise, the toe on the front passenger side is still a bit off after alignment, so I'm taking it back to get realigned with the longer camber bolts. Images are from a recent trip to Anza Borrego State Park Edited July 25, 2022 by Robertiko_138 Link to comment Share on other sites More sharing options...
Hellcat2003PF Posted December 8, 2022 Share Posted December 8, 2022 Year: 2003 LE Lift: 2" Coil Lft Tires: Michelin 245/65R17 Notes: No spacers used Just adding to everything, got set of 4x 1x 235/80R17 Treadwright Warden all terrain and 235/75R17 4x 1x Goodyear Wrangler A/T. What's the most likely to fit without trimming but also being the fullest looking, and if any going to work? Link to comment Share on other sites More sharing options...
