Differences Between 92 and 93
keithb7
I own a 1993 Pathfinder. I found a good used 92 that has tranny problems. I can pick it up for cheap and was thinking I may buy it for spare parts. Are there many differences? Both have V6. Mine has cloth seats and most every other option. The spare one must be the top model as it has leather heated seats and a sunroof. How similar are these two pathfinders other than the obvious? Thanks.
i am pretty sure they are all the same from 1990-1993. The dash got a little update in 1994-1995 years, but i think the rest is the same. The fenders, bumpers and rear body mounts might be a little different, but i need someone to verify that for me.
Yep, they should be identical other than trim and options.
Buy it, part pigs and spare parts are good!! You could probably recoup some of your expense buy selling extra parts here in the Classified section... ;)
Theres lots of little things that are different on my two SEV6s.
Map lights started in 93. - i had to add them to my 92.
93 has differnt bumpers and mounts up front. same turn signals
92 has abs ecu under the stereo, 93 under the seat
different hoods.
93 r134 - 92 r12 - converted mine. the condensors are the big differnce.
Thats all I have noticed so far.
