wspinks Posted April 17, 2008 Share Posted April 17, 2008 I have developed a clunk under the front end when at full lock, either direction, in reverse. I think it is probably loose tie rod ends, but I wanted to get some input before replacing them. What are your thoughts? Link to comment Share on other sites More sharing options...
Simon Posted April 17, 2008 Share Posted April 17, 2008 It could also be the steering stops. They're known to have the plastic caps fall off, and then you get metal to metal contact. if not, definitely tie-rod ends Link to comment Share on other sites More sharing options...
nissandoms47 Posted April 17, 2008 Share Posted April 17, 2008 Rack or tie rods. R50s have no steering stops. It is built into the rack. Link to comment Share on other sites More sharing options...
94extreme Posted April 17, 2008 Share Posted April 17, 2008 could be other things. not sure what full lock means though. why don't you check before you randomly replace parts? Link to comment Share on other sites More sharing options...
wspinks Posted April 18, 2008 Author Share Posted April 18, 2008 Full lock means that the wheels are turned fully in one direction. I was simply looking for ideas of other potential problems before I begin to diagnose anything. Thank you for your sincere input, it was most helpful. Link to comment Share on other sites More sharing options...
nissandoms47 Posted April 18, 2008 Share Posted April 18, 2008 Have someone wiggle the steering wheel while you take a look at your steering components. That will give you a better idea of what to replace. Ive seen everything from bad inner/outer tie rods to a back rack, bad rack bushings.. it could be a lot of things. It could even be something like a bad strut or something with the front suspension. Link to comment Share on other sites More sharing options...
wspinks Posted April 18, 2008 Author Share Posted April 18, 2008 Have someone wiggle the steering wheel while you take a look at your steering components. That will give you a better idea of what to replace. Ive seen everything from bad inner/outer tie rods to a back rack, bad rack bushings.. it could be a lot of things. It could even be something like a bad strut or something with the front suspension. Thanks, I will check those things out. Link to comment Share on other sites More sharing options...
Simon Posted April 18, 2008 Share Posted April 18, 2008 Rack or tie rods. R50s have no steering stops. It is built into the rack. D'oh...wasn't paying attention to the model of Pathy. Link to comment Share on other sites More sharing options...
nissandoms47 Posted April 19, 2008 Share Posted April 19, 2008 Its all good. I do it all the time lol. Link to comment Share on other sites More sharing options...
