Heidi Posted November 26, 2007 Share Posted November 26, 2007 I have the big black wind deflector thing that says "nissan" on the front of the roof rack on my 2002. It has gotten bowed (i guess from temperature changes) and is about a half-inch away from the roof in one place... now wind gets in there when driving and it vibrates / rattles against the roof like you wouldn't believe, sounds like someone is drumming on my roof. What do you suggest? Should I remove it, and if so, how? Can I repair it? Thanks! -heidi Link to comment Share on other sites More sharing options...
NismoSkyZ Posted November 26, 2007 Share Posted November 26, 2007 Try to get a heat gun and re-mold it. A half inch is kind of a stretch, but you could also try to silicone the gap too. Link to comment Share on other sites More sharing options...
navygz19 Posted November 27, 2007 Share Posted November 27, 2007 You can remove that fairing from the front, and as far as I know still keep the rest of the rack. Mine does the same thing and there's a TSB on this. The dealer actually has a repair kit for it which I'm sure is a complete, overpriced waste of $$. My advice? Remove it or learn to deal with it (that's what I've learned to do) Link to comment Share on other sites More sharing options...
Pezzy Posted November 27, 2007 Share Posted November 27, 2007 You could try the self adhesive clear rubber feet... These doo-dads. Link to comment Share on other sites More sharing options...
navygz19 Posted November 27, 2007 Share Posted November 27, 2007 (edited) You could try the self adhesive clear rubber feet... These doo-dads. Those look like implants...don't think they'll get rid of the noise Edited November 27, 2007 by navygz19 Link to comment Share on other sites More sharing options...
Pezzy Posted November 27, 2007 Share Posted November 27, 2007 mmm.. yeah, but they're like a half in inch wide. What a let down. Link to comment Share on other sites More sharing options...
navygz19 Posted November 27, 2007 Share Posted November 27, 2007 mmm.. yeah, but they're like a half in inch wide. What a let down. Oh, sorry, they look bigger than that...how deceiving. Link to comment Share on other sites More sharing options...
wspinks Posted November 27, 2007 Share Posted November 27, 2007 If you remove the wind deflector, I bet you will see that the plastic has pulled away from the metal support that runs across the middle. I used some Gorilla Glue and C-clamps and got everything to line back up just fine, really easy fix. Link to comment Share on other sites More sharing options...
Heidi Posted December 2, 2007 Author Share Posted December 2, 2007 Question for one of you who removed yours -- How do you get it off, i can't seem to find any fastening hardware that would affect it. I would like to take off this piece and try to repair it and reinstall it. I don't want to end up taking off the whole roof rack just to get at this one part if i don't have to... but i will if it's the only way. Please let me know. Thanx. -heidi :coffee!: Link to comment Share on other sites More sharing options...
wspinks Posted December 4, 2007 Share Posted December 4, 2007 The black plastic pieces at the front corners of the roof rack have to be removed in order to get to the screws that hold the wind deflector on. You will need to use a screwdriver to pop those pieces off. Link to comment Share on other sites More sharing options...
Heidi Posted December 11, 2007 Author Share Posted December 11, 2007 ok, those black corner caps did come off and whew we had the right tool to get those bolts off (they're not regular screw heads, they're the star ones). i'll indeed be glueing and clamping that flappy plastic part to the metal frame behind it, you're right it looks like they just had some double-sided tape and it's gotten hard and is peeling off... one more question, the two corner caps that i popped off with a screwdriver, each has 2 plastic posts with little silver teethy holders... three holders came with the corner caps, one stayed on the main part of the roof rack. does this matter when reassembling? thanks for all your suggestions and help! -heidi Link to comment Share on other sites More sharing options...
wspinks Posted December 12, 2007 Share Posted December 12, 2007 Probably not, it should still clip back in when you put it back together. Just make sure to line the plastic posts up carefully, when you clip them in, those things are pretty fragile. Link to comment Share on other sites More sharing options...
