ShadowManR6 Posted June 6, 2007 Share Posted June 6, 2007 What is the hose called that comes out of the top of the thermostat to the outlet in an 87" pathy, checked my chilton and alldata had no luck finding the name. Link to comment Share on other sites More sharing options...
MadManMike Posted June 6, 2007 Share Posted June 6, 2007 (edited) What is the hose called that comes out of the top of the thermostat to the outlet in an 87" pathy, checked my chilton and alldata had no luck finding the name. You mean the by-pass hose? I think this is the one that comes out the thermostat housing.. http://www.partsamerica.com/ProductDetail....065&PTSet=A Not sure if thats the one you are talking about but thought I would give it a try. -Mike Edited June 6, 2007 by MadManMike Link to comment Share on other sites More sharing options...
ShadowManR6 Posted June 6, 2007 Author Share Posted June 6, 2007 (edited) it sure is, thanks so much, time to get my truck back on the road rofl, this 100+ degree weather is killin me Edited June 6, 2007 by ShadowManR6 Link to comment Share on other sites More sharing options...
Slick Posted June 6, 2007 Share Posted June 6, 2007 oooooh.. i hate that hose. blew on me at 65mph... what a steam fest! Link to comment Share on other sites More sharing options...
barthel Posted June 7, 2007 Share Posted June 7, 2007 And they're a PITA to replace. I wrestled with mine for 15 minutes. Link to comment Share on other sites More sharing options...
ShadowManR6 Posted June 8, 2007 Author Share Posted June 8, 2007 well finally got the hose replaced last night, no leak (w00t). But after the truck overheated and started spewing the coolant it started getting a slight chug, now after ive replaced the hose i get a very constant chug, especially with the acceleration of the vehicle which actually causes it to accelerate extremly slowly as well as the loud chugging/vibration it causes, from what i can tell it seems to be coming partially from the muffle but possibly something else is chugging inside the vehicle as well. if i sit idle or accelerate very very slightly and slowly the slight chug is still present but doesn't seem to be quite as heavy as when i full on accelerate. Link to comment Share on other sites More sharing options...
Slick Posted June 8, 2007 Share Posted June 8, 2007 well finally got the hose replaced last night, no leak (w00t). But after the truck overheated and started spewing the coolant it started getting a slight chug, now after ive replaced the hose i get a very constant chug, especially with the acceleration of the vehicle which actually causes it to accelerate extremly slowly as well as the loud chugging/vibration it causes, from what i can tell it seems to be coming partially from the muffle but possibly something else is chugging inside the vehicle as well. if i sit idle or accelerate very very slightly and slowly the slight chug is still present but doesn't seem to be quite as heavy as when i full on accelerate. i thought chugging was something you did in a drinking contest? can you give a little more detail... like WHAT is "chugging".... what kind of noise is a chugging noise? your muffler wouldn't have much to do with any mechanical issue.... if it is shot, then all it will do is sound like ass and make rattling noises Link to comment Share on other sites More sharing options...
MadManMike Posted June 8, 2007 Share Posted June 8, 2007 is sound like ass And what does that sound like? Link to comment Share on other sites More sharing options...
Trainman Posted June 8, 2007 Share Posted June 8, 2007 i thought chugging was something you did in a drinking contest? can you give a little more detail... like WHAT is "chugging".... what kind of noise is a chugging noise?your muffler wouldn't have much to do with any mechanical issue.... if it is shot, then all it will do is sound like ass and make rattling noises The big diesel motors in locomotives are usually described as "chugging", so that is what I was thinking of. No idea of what it means in a Pathy motor though. Link to comment Share on other sites More sharing options...
ShadowManR6 Posted June 8, 2007 Author Share Posted June 8, 2007 (edited) like a loud puffing of air, in short bursts, thub thub thub, more i accelerate faster it thubs. As if i just went through a big puddle of water and it shot up into the engine compartment and got sucked into like the airfilter possibly, but i checked my filter and what not, and no antifreeze color in it whatsoever, what else could have possibly got filled or got water into it? could have gotten on distributer and maybe messed up one the spark plugs? Edited June 8, 2007 by ShadowManR6 Link to comment Share on other sites More sharing options...
GrimGreg Posted June 8, 2007 Share Posted June 8, 2007 like a loud puffing of air, in short bursts, thub thub thub, more i accelerate faster it thubs. As if i just went through a big puddle of water and it shot up into the engine compartment and got sucked into like the airfilter possibly, but i checked my filter and what not, and no antifreeze color in it whatsoever, what else could have possibly got filled or got water into it? could have gotten on distributer and maybe messed up one the spark plugs? Check your oil for water and your anti-freeze for oil. Might have blown a gasket when it got hot. Link to comment Share on other sites More sharing options...
ShadowManR6 Posted June 8, 2007 Author Share Posted June 8, 2007 when we changed out the pipe we checked the oil and wasn't discolored (was told it would be like a milky white if it got mixed) and from the anti freeze that we've seen it all seems to be normal. Link to comment Share on other sites More sharing options...
