tire pressure
tecciball
Hey Pathians.
I just got new tires for my Pathy - 255/70/16 Dunlop Rover A/T. I will be getting them installed next week. Does anyone have a suggestion on ideal air pressure for max tire life and fuel economy.
Just wondering what the common experience might be.
I run my Hankooks at 45 psi but they are 10 py LT rated tires, good to 80 psi :o
And at 45 it is a bit of a rough ride :P
What are the tires rated to? Are they P or LT?
If P, I would suggest keeping to the stock ratings and keep a good eye on them. Also ask the tire shop.
Draw a thick line of chalk across the tread of your tires, drive for about 3-4 tire revolutions and you can judge how you need to adjust your tire pressure by how the chalk rubs off.
If it rubs off in the middle, you're over-inflated.
If it rubs off on the shoulders of the tread, you're under-inflated.
If it rubs off evenly, you're just right! :aok:
It's like Goldilocks and the Three Bears. :lol:
That's a great way to define the benchmark for optimal treadwear.
From there, you may want to adjust slightly for conditions. Add a few psi more for a slight boost in fuel economy on ideal road surfaces. Lower a few psi for more traction in difficult conditions.
recommended tire pressure is 26psi at all 4 corners...
but it really depends on what your doing with them.
wheeling - different terrain = varying psi's (usually below 20psi)
driving - manufacturers rec. i found is always too low so i run 30-32 for the street
Yup... Just don't take it to the extremes Ford did with the explorers...
Go too low and tire failure is guaranteed. Lower pressure = more sidewall flex = more heat generation. Too much heat = Carcass delamination/failure/blowout.
I also forgot to mention, as you load her up, up the tire pressure but do not exceed maximum allowable by tire manufacturer. With the hatch full of camping gear and the trailer hooked up, I am up to 46 psi in the rear tires.
