fleurys
Vendors-
48
Everything posted by fleurys
I understand that this is not new but for me it is... http://www.cornay.com/pdfs/2003-04_4wheel_...road_spread.pdf In the upper left corner, team macpherson made a half-shaft for their IFS setup using 2 of these joints... Looks to me like the solution for fragile half-shaft on lifted r50.. Anyone know anything about these... Tks. edit : I found more infos a bit. Looks like Cooper tools carried the cornay joint under the name Apex. They list the product in there 2000 Universal Joint catalog : http://www.tecnoitaliasrl.net/scarica/07b_...rsal_joints.pdf ( have a look at page 6 !!), But it is not listed anymore in the 2007 edition : http://www.cooperpowertools.com/catalog/pd.../SP-1400_EN.pdf This tells me maybe that it got droped on the way...but canèt find why though...
Actually i,m trying to find which one is the most fragile : warn hub or near limit extended cv axles ?
Looking for some off-road experience.... If I was to have an arb locker in the front of my rig, and get plenny of traction while going up on a rock (let's say moab) and not yank it or anything, just steady throttle and plenty on traction, What would break first ; the hub or the axle ? now this is in theory... the question aplies to my rig while taking in account the AC lift with 32"...so the axle has a good extended angle while torque being applied... Just wondering..what would fail first if the forward progress was not possible and throttle was still aplied... Tks. edit : Also might as well ask, : is there any other cv axles available in diferent material (alloys) like chromoly or any other than the "regular" metal? if not and you had access to a custom shop, what materials would you make a cv axle of ?
got the same sh**t happen to me with my rancho rs9000xl...if the 5000 is also a gas filed shock, then they are defective...
go have alook here : http://www.nissanpathfinders.net/forum/index.php?showtopic=19867 you'll probably find your answer. s.
done .. keep this board up ! I think you're jumping too fast to conclusion... It's only been there 3 days and I just found out about the donations....so..i'm sure people will join in..
looking for the true type font for the NPORA logo.. I recently made myself some stickers but would like to try again with the right fonts...anyone has it ??
DTS214 is a part number from drivetrain.com...the TC in question is a T100L that you find in some nissan from 81 to 86. The high ratio is 1:1 and the low is 2.074:1 Could not find any other info about the manual vs auto... Maybe others that have the fsm for those years can help...
for rims I know for sure they do not do it, but tires , if you are serious about buying them and you let them know that if they fit you buy, I don't think there would be any problems... I guess that would be true if they have the tire in stock....probably not going to work if they need to order it... S.
not sure about this one...if the universal is not a wide band sensor, then the signal should still be between .2 and .8 volts.... S.
Hey Morpheus...since you work in a nissan dealer , I have a question. Do you think there is a possibility that I could get a used or defective one that is no good for them but still works enough for me to dismantle and see how it works ?? I mean free or very cheap... I don't know how it works..Do the dealer have to send the item back to nissan etc... give me some details as for what the options are for the dealer when they repair a truck with this TC...What do they do with the broken one ?? Tks.
I use 89 and saw a clear difference with fuel consumption compared to 92 or 94... I do more miles/gallon with the 89 octane.
photos ?? anyone out there rebuilding Transfer cases ?? any book or documentation (other than the fsm) that talked about this TC ? I slowly start to feel that i'm going to be on my own on this one
HELP: front suspension noise after installing new cv boot?
fleurys replied to fukkeneh240's topic in 96-2004 R50 Pathfinders
It would be a good one if it ends up being this.... -
no they're not....and when I say i can compress them by hand, i mean i put one end on my table and put the weight of my body on top to compress the other end... I am not able to compress them while holding the shock between my hands only... http://www.gorancho.com/products/shocks/rs...xl/rs9000xl.php
Tks... these shocks are gas charged (written on it)....and when I received the first one, you could clearly see that the box had been opened and re-taped... and at the time, eventhough I had ordered 2, they sent me one...They said all was left was some parts only and defective ones... So I think they put the leftovers of multiple boxes and did a full set for one...but the shock itself has no visible damage... the rs9000xl has a selectable resistance and with the second one I can clearly feel a difference between the smoothest and the hardest.. The first one, at the smoothest, is actually 3 or 4 time harder to compress then the second one at maximum setting... and changing the setting does not seems to change anything... I already communicated with them about getting a replacement... thanks for the clarifications.. S.
I ask here because it is the first time I ever buy a shock...anyway.. received my 2 rancho a week ago and decided to open them up tonight to prepare them (tie-rap the boot, put the sticker etc..) for the upcoming installation. To my surprise , the first shock, once compressed, stays compressed. While the second will go back to the extended position. I<m pretty sure the one defective is the first one, but just wanted to confirm with others first... Also, an insane ammount of force must be applied to the first shock to compress it.... So A normal shock, like the rancho 9000xl, should it come back to the extended position or should it stay compressed ? Tks.
sorry to interrupt here...is it possible the engine got simply hydrolocked ?? I mean, we all seen smaller puddle doing the job....so the engine might not turn because of that ?? Just a thought...
try typing this in the google search window : 1 inch in mm easy and fast..it works for many other conversions like : 210 AUD in USD
I have a 2001 with the ATX14A TC (auto mode) and looking at the FSM, it is clearly a different system than the more ocmmon tx10... Looks like it is a gear reduction system with planetary and sun gears... At first look, it surpasses my ability to fully comprehend the whole system. I'm just starting to educate myself to better understand how it works and what would be needed, if possible, to change the low gear ratio only from 2.6 to let's say 3.5 or 4... I'm not looking for replacement ideas (like change the whole thing for something else), but just a bit more information about this transfer case and the way it works. Fully understanding the way it reduces the gear ratio is the first step for me to start thinking about improving it... Thanks in advance..
bienvenue...have fun reading...ho yes also, try finding time to sleep in between
If those are in AU dollars, then it would be around 145USD$... not bad considering the finish and the threads idea...
I read everywhere that pezzy is a great off-road driver...but i'm starting to see a tendency here that she might not be so without some "minor" inconvenients, hahaha... sans rancunes, pezzy...
just installed skid plates , they went on easy
fleurys replied to jerry6's topic in 2005-2012 R51 Pathfinders
That seems like an understatement !! let us know what kind of beating they can take !
