shanee11
    88 terrano td27 ROUGH!!!!!
    Terrano R3m
    AUSTRALIA
    Australia
1,554 profile views
shanee11's Achievements
  1. thanks for the update on this very annoying aspect of our auto trans.. MY1PATH have you got any pics of wiring or a diagram of were you installed wires.. im not 100 percent up on auto elec stuff. i have tried all the same actions as others but this sounds neat and easy to install. thanks heaps ,, shane.
  2. hi all, after plenty of homework and phone calls i have leads on 2 auto boxs. one is 2001 pathy and the other is 2001 x trail. i know x trail is all wheel drive but would the auto be the type i am after for my terrano. thanks again for any info.. shane.
  3. good evening everyone,,, now,, my old terrano 1 automatic trans has died..specically i think the torque converter has issues and the lockup solenoid is faulty. i was thinking of replacing it with a trans from a terrano 2 as it would have a lot less km's.. so my question is what problems will we encounter to mate this to a TD27 diesel.. thanks in advance for any advice,, cheers, shane.
  4. gidday all,,, i would like to crank over the engine without it starting. its a 1990 terrano auto. the terrano has been sitting for about 3 months while i done some repair work. i would like to get some oil pressure up before it starts. whats the best method of doing this. thanks in advance, shane.....
  5. hi all, looking for ideas on replacing the rubber/ plastic side glass seals. these have shrunk over time and become brittle. i doubt if nissan would have any and the price would be scarey. what have others used ??? i have looked for pinch moulding without success. any ideas will be appreciated. thanks , shane..
  6. hi have just performed auto tranny fluid change. i didnt know how old the fluid was because i only recently purchased the terrano. i removed the tranny line near the radiator and run the engine to emptied the tranny, all went well. i have refilled with synthetic fluid but have overfilled the tranny. the level is about an inch to high up the dipstick. will this effect performance or cause any damage to the box. thanks in advance, shane
  7. hawairishthanks for info was trying to do one side at a time quiet simple when someone points out the right way will finish job in morning cheers .....
  8. hi everyone, i have a wd21 terrano 1990 well i have remove one of the tailgate gas struts to repair cracks in side section of tailgate these are due to pressure and leverage from regased struts repair went well but how do i get the strut back on ????? the pressure in these struts is amazing i can only just move them a fraction i have tried top bolt first and then bottom bolts first still no luck this maybe covered elsewhere on here but please help cheers,shane.....
